08-31-2012, 07:44 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Bangladesh
Member: 1162506 Status: Offline Thanks Meter: 177 | help me it shows Verifying communication to device... here is logo MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0873F5F Using device: USB ROM and HTI, FW ver: 00.50, SN: 01009F08 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B10020927FD7C56F9C1439156FE2F7F03C0879C CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2F76FC7 Verifying communication to device... ERROR: Could not verify communication ! Failed to set phone to flashmode, possible reason: Update Agent not running or PASUBTOC corrupted ! Please recover phone using FBUS. help me pls |
08-31-2012, 08:15 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: tamil nadu, india Age: 35
Member: 1772238 Status: Offline Sonork: 100.1617698 Thanks Meter: 126 | flash your phone once with fbus cable any errors then tick erase option and start flash, flash run succesfully without erase then u flash your phone with usb, dont forgot to remove the tick on ERASE option... |
08-31-2012, 08:49 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Use FBus Cable as Software says & post result. BR, ZUBER | |
08-31-2012, 12:04 | #4 (permalink) |
Member: 1162506 Status: Offline Thanks Meter: 177 | logo with f bus cable MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0873F5F Using device: HTI, FW ver: 00.50, SN: 01009F08 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0873F5F Using device: HTI, FW ver: 00.50, SN: 01009F08 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! |
08-31-2012, 12:12 | #5 (permalink) | |
Phone having Hardware Issue. Check or Change Avilma, Betty or Bluetooth IC's, if above error only for this Phone. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
