help me pls 3110c flashing error(ANSWERED) sir i received 1 nokia 3110c running phone with music player not open.so i flased it with mx-key. but after a while flashing stop and show this error. http://img121.imageshack.us/img121/3126/3110cg.th.jpg Uploaded with ImageShack.us i allready make bakup rpl.but now set not flash with usb so it is dead.hope team leader help me to recover my phone with the help of super mx-key dongle. |
mates try to flash again with higher version if it still the same use other box |
flash with ufs using extra power cable. with full ui default. |
it is cable problem, clean points and try again. |
it is cable problem, try other cables or use usb. u can try using hwk as well with these steps: 1. flash mcu only (tick skip erase) 2. flash ppm n cnt (untick skip erase) 3. pray :D good luck bro br |
correct me if im wrong :D br |
use 6 pin cable 100% ur problem solved. test by me many times. |
dear i use 7 pin universal cable with 10k. |
i allready try ur way and many times i also success.but with this phone i can not recover. |
may be u r r8.but i have 1 fbus cable and another universal cable.i try with both but problem still. |
i allready try with ufs-hwk with universal cable.problem still with this error http://img33.imageshack.us/img33/4488/3110cc.th.jpg Uploaded with ImageShack.us team leader pls don't mind for upload ufs report here. |
my dear sir i already used 7.30 version.if u have more latest version pls share with me |
rehot flash ic then flash with usb extra power cable & universal cable using 10k. |
set bsi 7.5k sir an flash again... |
i allready try this.but problem still |
