06-11-2013, 07:06 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. What is your problem ? Have you checked by clinking Buscheck Button ? Nokia 701 fully supported with USB, Please try Buscheck & post Logs if problem persist, Operation for Flashing is as usual like other BB5 Phones by connecting USB, Waiting for your reply. BR, ZUBER |
07-12-2014, 15:02 | #4 (permalink) |
Crazy Poster Join Date: May 2012 Location: hoshiarpur punjab india
Member: 1758220 Status: Offline Thanks Meter: 7 | MXKEY [FT SCR2000 0], SN: C084914B Using device: USB ROM Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: RM-774_113.010.1506_79u_prd.core.fpsx [BB5,XSR 1.6] size: 133.96 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: EC750000FFFB7C40897C22C2A534DC6A0E479E6E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 482EED7 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x22C bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35827204832578_CE RT.rpl" CMT PAPUBKEYS HASH: FEB3BB7481D3E5D0EAC907335A4402A071493D53 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 360.56 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [010C0000-170FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: FEB3BB74 [RAP Certificate v1 257] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 21.609 s Processing PPM file: RM-774_113.010.1506_18.01_India_79u_prd.rofs2.fpsx [BB5,XSR 1.6] size: 39.07 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 100 MB CMT FLASH,MuxOneNAND area [0D1C0000-135BFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 6.891 s Processing CNT file: RM-774_113.010.1506_U10.01_79u.uda.fpsx [BB5,XSR 1.6] size: 274.24 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 629 MB CMT FLASH,MuxOneNAND area [17100000-3E5FFFFF] Flash programming ... Programming completed in 1 min 1.578 s Total time for flashing process(boot+erase+write) was 1 min 44.156 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 1DD98886 Verifying communication to device OK. Phone type: RM-774 (Nokia 701) SW version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia ApeCoreSw: 113.010.1506 Imei plain: 35827---------- Product code: 059H219 Battery voltage: 3585 mV, current: 167 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3582----------- Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
