help me sir nokia asha shows phone restricted nokia asha RM rm 838 SHOWS phone restricted how to soive this problem |
post scan logs of your phone. discuss later. |
maybe your phone is not yet unlock or openline................... |
here is an log MXKEY [FT SCR2000 0], SN: C08547BA Using device: USB ROM Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 00000C201610004049922109B292E5D40AC9A100 [XGOLD 223] CMT PUBLIC ID: 077A7D869CDF31DC49922109B292E5D40AC9A100 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: FAF910DA218D8536CEFBDCE369A8C034160C6A5F Selected firmware certificate matched. Original Imei: Empty Original Product code: Empty NPC_DATA invalid ! SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x17B bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x2D bytes). Reading CMT HWC (0x16 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: AB84696 Verifying communication to device OK. Phone type: RM-838 (Nokia 308) SW version: V 05.85 23-10-12 RM-838 (c) Nokia Imei plain: 12345610654321-? Product code: 059N7Z7 Battery voltage: 4074 mV, current: 160 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: 0F5B6002002004, ver: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
This Phone not possible from you to solve, if Phone arrive with you in this status, Ask owner to sent this Phone to Technician, to whom he must have shown before you, May be he can solve it, if Non-Corrupted Backup RPL present in his PC, No other chance to solve, it's XGold Phone with Corrupted IMEI & Simlock. BR, ZUBER |
phone restricted .......i need help Reading Phone Info.... Connected phone - Nokia 308 Software ver : V 08.13 21-05-13 RM-838 (c) Nokia IMEI 1 : 12345610654321? IMEI 2 : 12345610654321? XappVer : 000008B6 PPM : V 08.13 21-05-13 RM-838 (c) Nokia EA1 CNT : Content: ea1_059N7X1 V 08.13 21-05-13 RM-838 (c) Nokia Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Battery: 4104 mV CMT BT: 0101-0.1.7 LCDVer: TPO Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 11 F1 Unable to read Lock table... :( Error collect lock info, try again IMEI DAMAGED!!! CRT308 save skipped... :( SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Ok Security status : Ok User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
