01-24-2010, 12:35 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 290637 Status: Offline Thanks Meter: 24 | Help In mx Key NK applet version: 00.20 Market items is empty, please select the correct products path ! You are connected using J.A.F interface Module activated with limited support! NK module ready. Market items is empty, please select the correct products path ! Please "Scan" or "BUS check" before any operation ... |
01-24-2010, 13:25 | #4 (permalink) |
Member: 290637 Status: Offline Thanks Meter: 24 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11826, Date: 22-01-2010 Boot error: 4F 4E 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
nokia6270 restore prob in mx-key pl help | debmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-08-2010 11:54 |
SD Auth in Mx-key Good news for mx-key user | muksforu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-28-2010 12:02 |
please help e66 unlock done or not done in mx-key any one try this | bijugreat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-20-2010 05:15 |
please help imei function in mx key | bijugreat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-07-2010 01:26 |
dead 6280 in usb flashing in other tool, how to revive in mx key????urgwent help need | peter002 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 10-28-2009 09:18 |
