04-09-2010, 07:33 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Help mx-key nokia 7250i contact service with battery[SOLVED] after flash this phone contact service with battery hire is after log Phone Type: NHL-4JX (Nokia 7250i) SW Version: V 5.41 09-02-05 NHL-4JX (c) Nokia. Imei plain: 35337100062165-4 Imei OTP: 35337100062165 Product Code: 0510760 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: C Language Pack: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Imei net: 35337100062165 Version: SIMLOCKLIB VERSION 2.28 -fix task:Extended number of TDS-6 boxes Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 4.031 s Imei net: 35337100062165 Version: SIMLOCKLIB VERSION 2.28 -fix task:Extended number of TDS-6 boxes Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Hire is self test report Phone Type: NHL-4JX SW version: V 5.41 09-02-05 NHL-4JX (c) Nokia. ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 1 AUX_DA_LOOP Y passed 3 EAR_DATA_LOOP Y passed 17 TX_IDP_LOOP Y passed 18 TX_IQ_DP_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 8 MBUS_RX_TX_LOOP Y passed 20 BACKUP_BATT Y !no signal 42 RADIO N passed 39 WARRANTY N passed 51 PA_TEMP Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY N passed 7 KEYBOARD_STUCK N passed 41 FLASH_CHECKSUM N passed 22 CAMERA_IF N !no signal 68 SW_TYPE_VALIDITY Y !failed ! 30 RF_CHIP_ID N !no signal 45 IR_IF N passed pls, can u help me ? |
04-09-2010, 10:17 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
reason ST_SW_TYPE_VALIDITY_TEST: 1. Flash you phone with latest pack - 5.41 (MCU, CP, PPM). 2. Make a copy of the MCU file "nhl4jx05.410". Open it with any Hex Editor and change the following addresses: (address: orig -> modified) DC: 24 ->73 E0: AE ->5F 107: 4A ->50 108: D6 ->81 37C964: 81 ->CA 37C968: 46 ->FD 38092F: E0 ->AB 380930: 89 ->00 380931: E8 ->7A 380932: 04 ->46 380933: 1E ->75 380934: 59 ->E8 380935: 93 ->44 380936: 4F ->39 380937: 39 ->4B 380938: FB ->97 380939: 59 ->1A 38093A: F5 ->07 38093B: 74 ->15 38093C: F6 ->A9 38093D: 6F ->24 38093E: F1 ->78 38093F: 14 ->2B 380940: C8 ->D6 380941: 67 ->FA 380942: 95 ->90 380943: 95 ->F5 380944: 73 ->3E 380945: 7C ->AD 3. Save it and then just flash the modified mcu file, by skipping authentication (Skip A on prodigy flash example). Erase only area 1 and 2, skip 3,4,5 and 6. | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
