01-05-2010, 12:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 55
Member: 59232 Status: Offline Thanks Meter: 5 | help for my firt mxkey use register ok, but when i like to unlock e71 scan ok soft read phone but when unlock i had this massage "device IO error :acces refusé code :5"and massage " confirmation :interface was forcible diconnected " box erreur :0000 box fw version :FF.FF i wait your help |
01-05-2010, 12:40 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | if ur problem is this http://forum.gsmhosting.com/vbb/show...&postcount=214 then see here http://forum.gsmhosting.com/vbb/show...66&postcount=4 |
01-06-2010, 19:40 | #7 (permalink) |
Member: 59232 Status: Offline Thanks Meter: 5 | with n85 to unlock soft give me this: all ok.....ok calculating NCK using security server.... connecting to server ok,login... failed to get key reading simlock info device IO error : acces refusé (code :5) what do you think ebout this problem !!!!!!!!!!! i wait answer , urgence thanks |
01-07-2010, 09:43 | #9 (permalink) |
Member: 59232 Status: Offline Thanks Meter: 5 | all ok.....ok calculating NCK using security server.... connecting to server ok,login... failed to get keyreading simlock info device IO error : acces refusé (code :5) ok but i can't unlock e71 too, ( i had unlocked it by by free zola soft ) regiser ok the pass sended by email i d'nt need and use it whay can you explain more what mean : failed to get key and device IO error : acces refusé (code :5) |
01-07-2010, 19:05 | #12 (permalink) |
Member: 59232 Status: Offline Thanks Meter: 5 | ok fist time i open soft i have this » OS version: 5.1.2600.2180 Service Pack 2 - Français (France) Main: » mobileEx.exe, version: 3.0.0.7306, date: 24-11-2009 » mobileEx.lib, version: 1.0.0.7037, date: 25-11-2009 Modules: » ccs.mx, library version: 1.0.0.1197, module version: 1.02, date: 23-11-2009 » nk.mx, library version: 1.0.0.11472, module version: 1.07, date: 27-11-2009 » siem.mx, library version: 1.0.0.293, module version: 1.01 B, date: 23-11-2009 » vcom.mx, library version: 1.0.0.1293, module version: 1.03, date: 23-11-2009 Loaded Drivers: » FTDI FTDIBUS, version: 2.0.0.0, date: 5-19-2006 » (Enhanced ports) oxser, version: 6.5.1.5, date: 1-24-2007 » Research in Motion RimVSerPort, version: 2.1.0.4, date: 1-9-2007 Save Energy to Stop Global Warming and to Save our EARTH !!! Fight climate change by supporting RAINFORESTS project: http://www.rainforestsos.org System: ¯ OS version: 5.1.2600.2180 Service Pack 2 - Fran‡ais (France) Main: ¯ mobileEx.exe, version: 3.0.0.7306, date: 24-11-2009 ¯ mobileEx.lib, version: 1.0.0.7037, date: 25-11-2009 Modules: ¯ ccs.mx, library version: 1.0.0.1197, module version: 1.02, date: 23-11-2009 ¯ nk.mx, library version: 1.0.0.11472, module version: 1.07, date: 27-11-2009 ¯ siem.mx, library version: 1.0.0.293, module version: 1.01 B, date: 23-11-2009 ¯ vcom.mx, library version: 1.0.0.1293, module version: 1.03, date: 23-11-2009 Loaded Drivers: ¯ FTDI FTDIBUS, version: 2.0.0.0, date: 5-19-2006 ¯ (Enhanced ports) oxser, version: 6.5.1.5, date: 1-24-2007 ¯ Research in Motion RimVSerPort, version: 2.1.0.4, date: 1-9-2007 Save Energy to Stop Global Warming and to Save our EARTH !!! Fight climate change by supporting RAINFORESTS project: http://www.rainforestsos.org after connect to jaf box i had this NK module version: 1.07 NK applet version: 00.20 Market items is empty, please select the correct products path ! You are connected using J.A.F interface Module activated with limited support! NK module ready. Market items is empty, please select the correct products path ! Please "Scan" or "BUS check" before any operation ... after update splock i had Imei net: 355708020836366 Version: SIMLOCK SERVER Provider: Orange + France Telecom Itineris, Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2080100000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F BLOCK 2: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11472, Date: 27-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... failed to get key! Reading Simlock info ... Device IO error: Accès refusé (code: 5) Device IO error: Accès refusé (code: 5) Interface: J.A.F (www.odeon.cn) » BOX FW Version: 01.B1 JAF FLASHER INTERFACE ready. Imei net: 355708020836366 Version: SIMLOCK SERVER Provider: Orange + France Telecom Itineris, Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2080100000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F BLOCK 2: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11472, Date: 27-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... failed to get key! Reading Simlock info ... Device IO error: Accٹs refus‚ (code: 5) what do think to resolve problem thanks |
01-09-2010, 05:56 | #14 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | are u have UFS interface ? that why we call it Code: You are connected using J.A.F interface Module activated with limited support! br, |
The Following User Says Thank You to Andra For This Useful Post: |
plz help for my mxkey | khm050 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-23-2009 12:58 |
IM BEGGING FOR HELP!for my P910i dictionary | sikreyto | Sony Ericsson | 0 | 06-25-2006 17:40 |
Help ... Help .... for my sgh-n500 | krasper | VLSI, Conexant, Skyworks and Old Models | 0 | 12-13-2005 12:53 |
Salam borthors i seeing help for my bluetooth use. | Bondho Khondkar | Bluetooth-Software | 1 | 12-13-2004 22:20 |
I need help for programming siemsens C35 using C | 05pch20 | GSM Programming & Reverse Engineering | 1 | 01-12-2004 08:58 |
