01-12-2011, 06:17 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Jamaica
Member: 279555 Status: Offline Thanks Meter: 11 | Help needed please after update to 1.8! DCT4PLUS license is not activated, invoking activation ... Starting License Activation ... Could not identify card, please restart application and retry ! MXKEY not assigned, please replug smartcard reader my card was activated long time ago and was working until i updated to the new version of mx-key. i tried to downgrade and still get the same problem. |
01-12-2011, 06:20 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Location: CellcomEngineering Age: 42
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | Quote:
problem solve.............. | |
01-12-2011, 06:26 | #3 (permalink) |
Member: 279555 Status: Offline Thanks Meter: 11 | Imei net: 010783xxxxxxxxx Counter: 0/3, 0/10 CONFIG_DATA: 3109990100000000 PROFILE_BITS: 1000000000020002 BLOCK 1: 1.LOCKED (MCC+MNC): DD - Updating SIMLOCK ...Error 7 DCT4PLUS license is not activated, invoking activation ... Starting License Activation ... SERVER->Served by MXKEY - BLADE Z at host1, agent version 1.1 revision 0.5 Card licenses Updated OK. Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5 [CR1]DCT4PLUS remaining credit: 47 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-65_01078300025957_SIM.RPL" after a while of restarting the application it started to work but deducting credits |
01-12-2011, 06:30 | #6 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | bro if you have less then 100 cradit then it counsume 1 cradit in every opration if you wan't unlimited support and not diduct cradit then make cradit more then 100 ...... |
01-12-2011, 06:45 | #8 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | because MCC+MNC is unknow! or not? don't use direct unlock try to patch unlock hope ur problem will b solved or use ufs3 software to unlock bcoz they are master in patch unlocking and no bugs in patch unlocking |
01-12-2011, 07:40 | #10 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | try to reinstall your mx-key software or disable your antivirus........ there is no problem in adding file ..................... |
01-12-2011, 07:54 | #11 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bangledashe ctg
Member: 884989 Status: Offline Sonork: 12000 Thanks Meter: 157 | alculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5 [CR1]DCT4PLUS remaining credit: 47 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
