09-14-2012, 10:04 | #1 (permalink) |
Junior Member Join Date: Sep 2012 Age: 43
Member: 1806653 Status: Offline Thanks Meter: 2 | help nokia c6 rm 612 someone advised me to try errasing the whole flash and downgrade this phone,i did that and now the phone is no longer booting up,it only vibrates when i press power button help urgent pliz |
09-14-2012, 10:57 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Where is your Buscheck Logs, No help without Logs, Follow Mxkey Rules for Posting here: http://forum.gsmhosting.com/vbb/f550...ection-984366/ BR, ZUBER |
09-14-2012, 13:32 | #3 (permalink) |
Member: 1806653 Status: Offline Thanks Meter: 2 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C085C098 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000C7D8 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: RM-612_42.0.004_prd.core.C00 [BB5,XSR 1.6] size: 111.93 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 11CCCD5 CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 07D0000462980252B01CE127A3FA702F85D9549E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 207.44 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 505A5C85 [RAP Certificate v1 228] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 31 min 33.930 s Processing PPM file: RM-612_42.0.004_prd.rofs2.V08 [BB5,XSR 1.6] size: 31.35 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 48 MB CMT FLASH,MuxOneNAND area [094A0000-0C49FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 9 min 4.480 s Processing PPM file: RM-612_42.0.004_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.96 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0C4A0000-0D39FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.149 s Processing CNT file: RM612_APE_ONLY_ENO_11w42_v0.020.fpsx [BB5,XSR 1.6] size: 2.68 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 4 MB CMT FLASH,MuxOneNAND area [00400000-007FFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 46.635 s Processing CNT file: RM-612_42.0.004_uda_2_001.uda.fpsx [BB5,XSR 1.6] size: 56.79 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 283.75 MB CMT FLASH,MuxOneNAND area [0D3C0000-1EF7FFFF] Flash programming ... Error while programming [00] at 0x0DD80000, Result: 0000 |
09-14-2012, 13:55 | #4 (permalink) |
Freak Poster Join Date: Apr 2012 Location: forum.gsmhosting.com
Member: 1745022 Status: Offline Sonork: Save The Market Thanks Meter: 40 | looks different problem, what was the history of phone? try to flash with same product code flash files with higher version; make sure u have full charged battery and usb cable is short & good;; try & post results, we r here to help u |
09-14-2012, 15:01 | #5 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Use FBus Cable & Flash it, Only use Latest Firmware of your Phone Product & post result. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
