::...>>>how can I repair sp 1202 ? hello for all i need help about repair sp for 1202 ( contact service ) with mobileEx 3.4 (rev1.0) what procedures to do this function ? ( explain with picture ) what did I done ? i went to dct-4 > service > IMEI & SECURITY > SIMLOCK AND i marked on Direct unlock and select Init simlock and clicked on update splock I got on this error Code: Failed to read SP data best regards |
Bro, is it Rh-111 or RH-112, FYI, Rh-111 is not possible to flash or unlock as it is based on infineon platform. if it is Rh-112, then full flash it first and try again. |
it is rh-112 what procedures to do this function ? ( explain with picture ) thanks |
first erase phone,then flash.write pm, and unlock...................... still same problem then check in hardware like water damage,etc............... Guljee |
just write pm. Quote:
I DO ALL THING, but still same problem ( erase ,full flash , write pm ) scan Quote:
update splock Quote:
sory for jumping others thred i too facing same problem is there is any solution for this phone? Phone Type: RH-112 SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: xxxxxxxxxxxx Product Code: 0562205 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: AA Language Pack: - not available. Failed to read SP data Failed to read SP data Imei net is empty, process aborted. |
repair sp date for 1202 Is it supported or not? |
Check........ http://forum.gsmhosting.com/vbb/5843468-post1.html |
this software not from mx key team I can't use it anyway thanks for you |
check ....... http://forum.gsmhosting.com/vbb/5753767-post1.html don't worry , you are new member don't done it again |
Manole Eat Ur Credit Like Monkeys all operation faild frome bad servers and ur credit eaten:p at last dont ask him for back ur credit and u can have blocked dongle in any time frome this big cheater in gsm:p |
Oh Yup May Be Manole:D |
you problem here Quote:
We are respectable people , brother please don't use bad words I respect all regards |
