Old 02-12-2012, 20:25   #1 (permalink)
Member: 49975
how desable Short Circuit Detected (ANSWERED)
problem with orange hti box, when connect universal cable, without phone, detect short circuit, when connect ufs f-bus cable work normaly. when i use green box work good with f-bus and universal cable. Maby I can diseble this funcion or this only orange box problem. I tried with three different orange box, The problem is most.
or otherwise update this one problem will disappear
Old 02-13-2012, 09:45   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. if you had tried with three orange box that means box are ok, may be your usb to box cable must be shorting, so change box's cable may solve your problem.
Old 02-13-2012, 10:41   #3 (permalink)
Member: 49975
usb cable ok, becouse green box work ok, only orange box not work with universal cable.
Old 02-13-2012, 11:02   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
have you tired another cable?
what if no cable plugged? still short circuit detected?
Old 02-13-2012, 11:18   #5 (permalink)
Member: 49975
no cable plugged work ok, when use f-bus cable, like jaf or hwk cable it work ok, not work only with universal cable UFC-4. i have 2 orange box, and one green box. green box work ok. it problem only with orange new boxes.
Old 02-13-2012, 12:14   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. dont confuse as green box & orange box, usb to box cable of both are different then how you are telling that green box working, orange not working & cable is ok, cables are different then how its works ok?
Old 02-13-2012, 12:20   #7 (permalink)
Member: 49975
Trust USB cable is really good. I tried with another computer and another USB cable
Old 02-13-2012, 12:24   #8 (permalink)
Member: 1049117
Thanks Meter: 7
Friend the universal cable which brand or ipmart UFC GPG
Old 02-13-2012, 13:07   #9 (permalink)
Member: 49975
so maybe the old model, but work with all boxes, atf, cyclone, jaf and HWK but not work with orage HTI box. I think that the new model will not work with orange box.
Now I had an idea, maybe work with an external power supply. It will be necessary to test this evening.
Old 02-14-2012, 02:17   #10 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Ok, please test it and report. I am waiting for this.
And one more thing, please do not post any external links like you posted.
Here is not sales section, you could post the picture of your cable.
BR,
Manole
Old 02-14-2012, 12:25   #11 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
I think UB cables have somehow pin 2 of RJ45 connected to something.
Try remove or desolder pin 2 from your cables, or make a small adapter who connect all other 7 wires except the pin 2.
For pin numerotation check this:
http://pinouts.ru/connectors/rj45m.gif
BB5_cable.gif - 4shared.com - photo sharing - download image
or more easy, pin 2 is the one between Phpne VCC and BSI.
PLEASE report your result.
Manole
Old 02-14-2012, 22:14   #12 (permalink)
Member: 49975
with an external power supply problem remains the same. But when I choose different positions as like MT box or cyclone box work for the cable, short circuit disappears. I can scan the info and BUS CHECK. I think the problem is solved. With a green box can I use the universal cable like JAF cable, but with orange box I can use the universal cable like Cyclone cable.
Thank you all very much
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.20142 seconds with 9 queries
