11-13-2010, 08:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | how to remove security code nokia x2 (step by step guide) Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 25E79593 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00CFE883013BB7DBC4E81DF3825B53E50705C3FC CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 25E79593 Verifying communication to device OK. Original Imei: 35269904954641 Original Product code: 0595304 Bluetooth ID: 80501B87724D Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Pooling for ADL device ... Device found: nmwcdc\Nokia X2-00 USB Generic, ID: 2CC82ED7 Verifying communication to device OK. Phone Type: RM-618 (Nokia X2-00) SW Version: V 04.25 14-06-10 RM-618 (c) Nokia Imei plain: 35269904954641-2 Product Code: 0595304 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352699049546412 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA is empty. PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA is empty. RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35269904954641_12 89579936_BACK.rpl" FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.390 s 1st. download files from mxkey support 2nd.open mxkey select nokia usb connect 3rd.select files (i mean mcu ,ppm ,cnt 4th. bus check 5th. goto service option 6th.reset all or read code use usb c101 THANKS TO MXKEY |
The Following 11 Users Say Thank You to sajid11 For This Useful Post: |
11-13-2010, 11:28 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
11-15-2010, 10:21 | #5 (permalink) | |
Freak Poster Join Date: Mar 2009 Location: Bangladesh
Member: 992629 Status: Offline Sonork: 100.1624926 Thanks Meter: 31 | Quote:
any body test it................... | |
11-15-2010, 10:31 | #6 (permalink) | ||
No Life Poster Join Date: May 2007 Location: INdIa
Member: 517316 Status: Offline Thanks Meter: 185 | Quote:
You are WRONG............ Read carefully first post Quote:
11-15-2010, 13:46 | #8 (permalink) | |
Member: 714116 Status: Offline Thanks Meter: 48 | its not fake post Quote:
11-15-2010, 16:18 | #9 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | Quote:
12-04-2010, 06:25 | #11 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Erirea
Member: 825233 Status: Offline Thanks Meter: 10 | for me did not work here is the log Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 236F57D7 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: 000000000023E3E2ABF9A7CD3CBF193693373955 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 236F57D7 Verifying communication to device OK. Original Imei: 35434604825951 Original Product code: 059C1H1 Bluetooth ID: 1814564BEF41 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Pooling for ADL device ... Device found: nmwcdc\Nokia X2-00 USB Generic, ID: 394FEFE6 Verifying communication to device... Verifying communication to device... Communication lost, phone not found. Phone not responding ! |
12-04-2010, 11:20 | #14 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | sorry bro, i just want to ask u that is it possible after bus check it will show full info in usb mode when phone is security lock. please i want answer because my mxkey dont show full info & service option in usb mode when phone is having security code. |
12-04-2010, 11:29 | #15 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | man, read my above post & then answer , i am member of this forum from 5-6 years but i post when i understand what to post & dont put my legs in between,take knowledge as many as you can, so from next time you also PLEASE TEST BE4 POST. |
