Old 06-02-2011, 03:58   #1 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
Question how remove user code Nokia C3-00 via USB cable?(ANSWERED)
i have a Nokia C3-00 Rm-614, and i want remove the user code.
I try to flash via usb, and nothing happen.
Help please!!! But be expecific in the explain?
Old 06-02-2011, 04:47   #2 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
contact me at yahoo...
i will help u
Old 06-02-2011, 05:30   #3 (permalink)
~The JoKeR~'s Avatar
Member: 1051835
Sonork: 100.1594332
Thanks Meter: 514
first bus check with any version of mcu file
then set go to test mode and mxkey show services goto imei and security read usercode
Old 06-02-2011, 05:42   #4 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
[IMG]http://2.bp.********.com/-Brd-cDiFvy4/TeXEq8cosdI/AAAAAAAAAoM/0NAR6nlOCy0/s1600/MTP+Device+ERROR.JPG[/IMG]
See the pic, i have the MTP Device Error and i install the MTP Kit from microsoft. i flashed the phone very times and nothing!!!
What i can do, to reset de user code????
Old 06-02-2011, 05:50   #5 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
Are you sure that you can bus check via usb cable for broadcom chip.
Old 06-02-2011, 05:55   #6 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
Question
?????What is Broadcom chip, you refer to the motherboar of CPU?
Old 06-02-2011, 06:01   #7 (permalink)
Member: 209722
Thanks Meter: 818
do full flash for removing user code.
Old 06-02-2011, 06:07   #8 (permalink)
Member: 623065
Thanks Meter: 27
write pm coz password in pm
Old 06-02-2011, 06:50   #9 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
yeah i flash the mcu and ppm files a lot of time, only change the languaje, but the code is here. not remove with flash
Old 06-02-2011, 06:52   #10 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
Question
can i flash only the PPM?
who do this in th e c3-00? reset the user code?
Old 06-02-2011, 06:59   #11 (permalink)
abidfarooq's Avatar
Member: 102445
Sonork: 100.1603645
Thanks Meter: 77
You can do it on an easy way with usb. put 8.2k resistor between gnd and bsi once you see local or test mode in screen then press factory reset on phone.
wbr
abidmobile
The Following User Says Thank You to abidfarooq For This Useful Post:
Old 06-02-2011, 08:28   #12 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
ok, i will do this tomorow
Old 06-02-2011, 08:56   #13 (permalink)
jaijee's Avatar
Member: 450110
Thanks Meter: 187
bro, in usb mode,
after flash,
service tab is open.....
go action and you can do full factory reset.........
Old 06-02-2011, 10:01   #14 (permalink)
nolimitkenya2's Avatar
Member: 1341599
Thanks Meter: 114
Da only way is to flash da phone via usb& do factory reset,its cool av done it so many times
Old 06-02-2011, 17:20   #15 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
Here is schematic for modified usb cable! Enjoy!
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.20763 seconds with 10 queries
