07-01-2010, 17:23 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: soft com
Member: 544129 Status: Offline Thanks Meter: 32 | how repair 2680 contect service ? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008ECD39A3BDA66 ASIC type: 11 UEM Imei: 353198***** Flash Imei: 353198******* MasterCode: 2606663336 RPL saved to "C:\mobileEx\3.4\data\backup\353198******_BACK.rpl " Phone Type: RM-392 (Nokia 2680s-2) SW Version: V 05.28 05-11-08 RM-392 (c) Nokia Imei plain: 353198******* Imei OTP: 353198******** Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: IC Language Pack: - not available. Failed to read SP data i try to unlock it but give error simlock data currupt ? |
07-01-2010, 17:56 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
BR curvenger | |
The Following User Says Thank You to curvenger For This Useful Post: |
07-02-2010, 10:32 | #5 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | br. this is dct4+, u check phone test or self test, check info, ur sim ic is ok? if ok. do the following job:- (n.b. before start must collected pm file for 2680.) 1st step. 1. earse ur phone. 2. flash phone. 3. write pm 4. ui setting. phone ok? not ok do:- 2nd. step. (YOUR IMEI WILL BE LOST, NEED AGAIN IMEI WIRTE) 1. reset data1 (ur phone imei will be lost) 2. flash ur phone. 3. write imei 4. write pm 5. ui setting i hope ur phone cs must solve. thanks mahir ashab |
07-02-2010, 11:02 | #6 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Quote:
he just need to unlock his phone with patch or RSA Because SP Data is crrupted and its better that after unlock write full pm | |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
