04-14-2010, 11:16 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | How to repair imei on 1100????? Easy Imei restore for DCT4 phones started. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C1D4AA:2984DA60 ASIC type: 2 UEM Imei: 35883200xxxxxx Flash Imei: Empty Invalid imei checksum ! Investigating flash imei ... Flash imei is empty, checking for RPL backup ... Phone backup is NULL, you need RPL to restore imei! ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C1D4AA:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: ??????????????-? Product Code: 0512532 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: EE Language Pack: English,German,Hungarian,Romanian Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: CE1DDE20D53F579A PROFILE_BITS: C127E0D3CC6E94A4 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! How can I repair this phone?...I have no backup and I had read ask, so where I have to upload it to get rpl file for this phone????? |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
