08-19-2009, 10:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | help with 5220 here is the log: Code: RPL: "C:\mobileEx\3.2\data\backup\BB5_35366201256303_BACK.rpl" Imei: 35366201256303 Updating PRODUCTCODE (0570522)... OK Updating PSN (DQG091990)... OK Updating HWID (1000)... OK Updating SIMLOCK...OK Updating SUPERDONGLE_KEY from backup ...error 0x0 Updating WMDRM_PD...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK Restoring RF/BB DATA from backup ... Using device: J.A.F, FW ver: 01.B1 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 2080010ED5E25550A9AB8A96573EEC10DF301FEC ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B Erasing CMT NPC ... OK Updating RF ...OK Updating BB ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 2080010ED5E25550A9AB8A96573EEC10DF301FEC ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 06.51 23-03-09 RM-411 (c) Nokia Imei plain: 35366201256303-7 Product Code: 0570522 VariantId: I Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! SIMLOCK_TEST passed SECURITY_TEST passed Imei: 353662012563037 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
08-19-2009, 21:17 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | this model have sl2 protected firmware inside (This phone have PM308 protected, SD security in not restorable.) but u can try with this step: reflash again low mcu version only without marking downgrad options select fix bb5 downgrade restore ur buckup reflash ur phone full flash again with last version |
08-22-2009, 14:21 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
Try this solution, open the link below, http://forum.djawir.com/mxkey-dongle...npa-rpl-41283/ http://www.bestncheap.net/showthread.php?t=7791 Last edited by swechacnu; 08-22-2009 at 14:26. | |
08-25-2009, 20:43 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Quote:
the problem is that we only understand English | |
E72 keep restarting ..... any help with hardware solution?? | abu_nairoukh | Nokia Hardware & Hardware Repair | 4 | 12-14-2010 11:10 |
Problem with 5220 RM-411 unlock | mobista | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-16-2010 17:21 |
help with 5220 contact service? | mahdiqaladza | Nokia Base Band 5 ( BB-5 ) | 3 | 10-30-2009 00:01 |
Help with nokia 5220 | abuiesa | Nokia Base Band 5 ( BB-5 ) | 1 | 09-06-2009 14:25 |
helpme with 5220 please!!!!!!!!! | juan1983 | Cyclonebox | 10 | 08-22-2009 18:19 |
