How to repair SD NOKIA N96 ..!!! phone come to me with Simlock data corrupt and" phone start up failed "after flashed with another tool.. so I did write it's full pm backup using super sd auth but the phone became only nokia logo then go off..the I make repair simlock (make rpl simlock) and simlock repaired..but phone still as it (nokia logo then off).. plz help me with steps to repair it.. Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35486302663277-1 Product Code: 0543727 ApeCoreSw: 30.033 ApeVariant: 30.033, 30.033.010.1, 30.033.098.1 ApeTest: ENOSW_4032_PR11.0835_003 ContentPack: V 40.2009.25.xx PRD Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354863026632771 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
i have same n96...identic problems...everyone one response??pls.. |
try this simple ............... |
I tried b4..I already make sd repair then write it's full pm backup..but somtimes it fails when it's write field 1 and 309 and sometimes it write it..but still same..is it could be pm prb..?? do u have good pm or 1,309 good pm..so I can try it..! |
Good luck! |
I write full pm from working phone then i make sd repair..then what what other instructions plz |
your last log info from phone ? do "BB5 secure Validation" what do you get ? br, |
after writing full pm from working phone with skipping writing 120,308 fields phone still same..! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: 2298802FAE18DB4D0436631765D0ABD19151D15E ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B500011AEDA015836D0F591AB38E30B114D4E2F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE ALG [35]: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Original Imei: 35486302663277 Original Product code: 0567011 Bluetooth ID: 0025CF3753B3 WLAN ID: 0025CF383E13 Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35486302663277-1 Product Code: 0543727 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2008-11-27T11:07:47+00:00 SW Version: 12.043 Variant Version: 011 ProductProfile: Simlock: simlock_3gstandard_bb5.bin Imei net: 354863026632771 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF any ideas..? |
Yes I have tried that ..and here is log for "BB5 SECURE VALIDATION): Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia ApeCoreSw: 30.033 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. - 120 skipped - 308 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 1.875 s APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: 2298802FAE18DB4D0436631765D0ABD19151D15E ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B500011AEDA015836D0F591AB38E30B114D4E2F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE ALG [35]: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Reading RAP NPC (0x1B8 bytes) Original Product Code: 0567011 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0543727 Product Code missmatch ! Reading RAP HWC (0x0 bytes) |
I wrote rpl without NPC from files that manole thread offered..and then make write full pm>simlock repair>repair sd>super sd auth>write pm 1,309 still same..! APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: 2298802FAE18DB4D0436631765D0ABD19151D15E ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B500011AEDA015836D0F591AB38E30B114D4E2F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE ALG [35]: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Reading RAP NPC (0x1B8 bytes) Original Product Code: 0567011 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0543727 Product Code missmatch ! Reading RAP HWC (0x0 bytes) |
