05-09-2011, 08:51 | #5 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | Quote:
I all ready do that but allways say field........i want to try reset x2 phone user code pls help me................... Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 595D3B3 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000613F84939A8749688C3F9F304FF2BA CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 595D3B3 Verifying communication to device OK. Original Imei: 35434604704539 Original Product code: 0595278 Bluetooth ID: 18145629E6B9 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Waiting for device boot up ... Device found: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 1604DBDB Verifying communication to device... Verifying communication to device... Communication lost, phone not found. Phone not responding ! Reset User Code (to default:12345) ... Failed! Completed in 17.171 s | |
05-09-2011, 09:05 | #6 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | Waiting for device boot up ... Device found: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 1604DBDB Verifying communication to device... Verifying communication to device... Communication lost, phone not found. Phone not responding ! Reset User Code (to default:12345) ... Failed! Completed in 17.171 s bcoz your phone not go in Local Mode. |
05-09-2011, 09:14 | #7 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | read write user code in usb mode is easy. find and buy this resistor 1------3.3K 2------4.5K 3------5.1K i use 3.3k remove phone battery, connect on of this resistor in BSI and GROUND point. insert battery and power on your phone. now your phone directly go in local mode. after local mode you can remove your resistor no problem. connect usb cable open software and do what u need. in my case i just make a touch in phone BSI and GROUND line in my resistor and press power button after phone local mode i remove resistor. save your time and do best. BR net.tarik |
The Following User Says Thank You to net.tarik For This Useful Post: |
05-11-2011, 06:53 | #8 (permalink) | |
what can i do now?? any other solution???? | |
05-11-2011, 07:19 | #9 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | all resistor r kilo ohms. in bsi to ground line we can use this resistor 3.3/4.5/5.1/7.5/10/15 kilo ohms. and check battery charge, it needs fully charged battery. BR |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
