Old 07-01-2012, 09:11   #1 (permalink)
Member: 715306
5610d-1 contact service...plz help me
Here is mobile info log with mxkey:
Phone type: RM-242 (Nokia 5610d-1)
SW version: V 10.00 06-03-09 RM-242 (c) Nokia
Imei plain: 12345610654321-?
Battery voltage: 4605 mV, current: 107 mA
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
SIMLOCK_DATA
corrupted!
I have RPL Backup!!!
So kindly guide me !!
Old 07-01-2012, 09:47   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. Follow this:
1. Go to Service Tab>IMEI & Security Tab>Click Restore IMEI.
2. Go to Service Tab>PM Tab>Click Super SD Auth, then Click Repair SD will do the Job.
Have a nice day.
BR,
Zuber Chowdhry
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 07-01-2012, 10:01   #3 (permalink)
R.G.mobiles's Avatar
Member: 1724303
Sonork: 1611265
Thanks Meter: 70
if u have back up file so solve your problem
and other by new rpl for imei
The Following User Says Thank You to R.G.mobiles For This Useful Post:
Old 07-03-2012, 09:17   #4 (permalink)
Member: 715306
bro i do restore imei::
RPL: "C:\mobileEx\3.5\data\backup\RPL\BB5_3529410209291 6_BACK.rpl"Imei: 35294102092916
Restoring RF/BB DATA from backup ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101013000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 11400101BC980254528F641FE4F3E10C138ABE16
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating BT ...OK
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C08450E5
Using device: HTI, FW ver: 00.50, SN: 0000E5FC
Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
CMT PAPUBKEYS HASH: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Prog.status for Asic CMT ...
NOR: OK
Updating SIMLOCK ...error 0x1Updating CMLA_KEY ...OK
Updating WMDRM_PD ...OK
Battery voltage: 4667 mV, current: 109 mA
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
now how i do??? plz step step help me??
tanx...
Old 07-03-2012, 09:51   #5 (permalink)
Member: 1724303
Sonork: 1611265
Thanks Meter: 70
write back up file
f1st try restore imei
contact me on [email protected]
Old 07-03-2012, 09:59   #6 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 370
first erase 8mb 16 mb and 32 mb bb5 erase file and do full flash write imei ur problem solve
if not contact [email protected]
Old 07-03-2012, 10:14   #7 (permalink)
Member: 715306
Battery voltage: 4642 mV, current: 116 mA
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
now how i do??plz help me
Old 07-03-2012, 12:38   #8 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Bro. did this Backup taken before or now when phone come to you for Repair.
If it's old Backup, then Erase Phone with this Method: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ , After Flashing don't Restore IMEI & Write Backup RPL Manually by Clicking Write on RPL Button. Your Simlock will be Valid. Buscheck & do Remaining Jobs for errors.
If not solve means your Backup is Incomplete or Bricked. needs to buy RPL. Have a good luck.
BR,
Zuber Chowdhry
Old 07-23-2012, 11:15   #9 (permalink)
Member: 715306
BR,
Zuber Chowdhry
Tanx bro for answer...
I buy RPL ...
first erase phone and flash phone with latest version(10)
then when wrote new RPL Give me error for update simlock...
this is log by mx...
Updating SUPERDONGLE_KEY ...OK
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550
NOR: OK
Battery voltage: 3857 mV, current: 57 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SIMLOCK_TEST passed
now how i do...!!??
Old 07-23-2012, 11:32   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. Tick Repair Simlock & Click Repair SPLock, Post result.
BR,
Zuber
Old 07-23-2012, 12:33   #11 (permalink)
Member: 715306
this is log with jaf then wrote rpl...
Scanning RPL file...
NPC DATA OK...
VARIANT DATA NOT FOUND...
CCC DATA OK...
HWC DATA OK...
NPC APE DATA NOT FOUND...
VARIANT APE DATA NOT FOUND...
CCC APE DATA NOT FOUND...
HWC APE DATA NOT FOUND...
SIMLOCK DATA OK...
SIMLOCK KEY DATA OK...
SUPERDONGLE KEY DATA OK...
CMLA KEY DATA OK...
WMDRM PD DATA OK...
Connecting to phone...
Writing SIMLOCK DATA and SIMLOCK DATA KEY...
Writing SUPER DONGLE KEY...
Writing CMLA KEY DATA...
Writing WMDRM PD DATA...
FAST PHONE detected!
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 220C00EC <=> SAMSUNG (SEC) -> K5G1257ATM
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Writing NPC DATA...
Writing CCC DATA...
Writing HWC DATA...
Restarting phone...
Done!
but no correct IMEI....
Old 07-23-2012, 12:34   #12 (permalink)
Member: 715306
BR,
Zuber
SW version: V 09.40 07-11-08 RM-242 (c) Nokia
Using cached productData.
PRIVATE ID: DAB245DB6E2CA7321F41813708E20D91AFDA6272
Reading Simlock info ...
Old 07-23-2012, 12:45   #13 (permalink)
alyas_ashiq's Avatar
Member: 1112242
Sonork: 100.1617813
Thanks Meter: 126
CONTACT ME ON YAHOO
U R PROBLAM 100% SLOVE
[email protected]
Old 07-23-2012, 12:50   #14 (permalink)
Member: 715306
please help me friends....
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.30640 seconds with 9 queries
