12-29-2009, 12:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | how to write pm308 value? |
12-29-2009, 12:38 | #2 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | what to do if Connecting to server ...OK Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[mxkey.selfip.biz] ...Connection refused Connecting to server[mxkey.selfip.biz] ...Connection refused Connecting to server[mxkey.selfip.biz] ...Connection refused |
12-29-2009, 12:43 | #3 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | okay when i change the server then check this log Section: 308 Warning: failed to write 308 - 1 (8192 bytes) Warning: failed to write 308 - 9 (40 bytes) Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 322 Section: 329 - Key: 0, size 8392 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4520 bytes written. Section: 354 - Key: 0, size 15 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Section: 363 - Key: 3, size 3 bytes written. - Key: 4, size 7 bytes written. - Key: 5, size 7 bytes written. Completed in 12.297 s |
12-29-2009, 16:10 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | just follow the instructions in this thread http://forum.gsmhosting.com/vbb/show...54&postcount=4 and unlock it using the old version of mx-key. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
12-29-2009, 16:58 | #7 (permalink) | |
Member: 303790 Status: Offline Thanks Meter: 290 | Quote:
12-29-2009, 17:54 | #8 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | no its not working here is image i try both of boxes like jaf and saras and please any one give me the link about cross flash because i was see but now forget that how to do |
12-29-2009, 21:27 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | b) you must have the full PM back-up of the mobile, all the certs, the RPL from Phone and ready a full PM120 and 308 of the mobile in original state . c) You may need a TMA adapter to do the job... You need to download as well the erase file for the 6220, the eno firmware for the mobile, a good PM and a firmware for e71 V100 and istall this one in the folder where we normal keep the firmwares with the final path \RM-346\ (Sample c:\Program files\Nokia\Phoenix\Products\RM-346\) step 1: flash the mobile with the erase file 6220_Erase_256MB_kashi4gul with "Skip APE" Thicked. once you erased the mobile do check flashing bus to see if you can read the mobile on the fbus.. if not connect your tma adapter and add 2,2Kohm (Switch 2 ON all the others OFF) unplug the cable and plug it again and retry to check the flashing bus step 2: flash the mobile as E71 v100 product code 0559569 with "skip APE" thicked ONLY COR and PPM. the mobile now should be readable and you can see the infos with damaged imei as you are working on a RM-346 step 3: write the PM 120 and 308 you have from the original back-up ot the unlocked ones step 4: flash it again with the 6220 firmware was in origin in the mobile step 5: write back the RPL Back-up made in origin : if you now read the infos in the mobile the logs will be perfect with the mobile locked again as before step 6: click on sx4 auth.. the mobile should get the sx4 auth without any problem step 7: write the good PM . BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
01-02-2010, 16:00 | #10 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | dear as your thread i do every thing but i lost the super dongle data and the sx4 is not done with this i save all back ups cert and full pm and also 120 value and 308 too but how to sx4 for to write these values |
01-04-2010, 09:54 | #12 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | dear sir as after the erase the flash i need to restore backup and pm also so when i go to the sx4 its say me the super dongle data is invalid and its give error to sx4 so how to restore ma backups without the sx4 i have full cert and full pm to |
need to know how to write gdfs to K800 | dapinderjit | Sony Ericsson | 9 | 03-15-2010 22:59 |
Does anyone know how to write PM308 do without the need for SX4? | 1236547890 | Nokia Base Band 5 ( BB-5 ) | 0 | 10-31-2009 22:19 |
how to check register value [use in 5200 mmc jumper] | shivam4you | Nokia Hardware & Hardware Repair | 3 | 01-28-2009 21:06 |
Problem trying to write PM308 to N95 | tito millo | MT-BOX | 8 | 11-09-2007 18:44 |
how to edit the Values of life timer nokia3310 ? | the_frightener | Nokia Multimedia | 2 | 05-25-2003 22:56 |
