Old 05-23-2012, 17:02   #1 (permalink)
Member: 934255
Thanks Meter: 63
Solution for this log? only new rpl or not?
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF0A021001, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Old 05-23-2012, 17:03   #2 (permalink)
Member: 934255
Thanks Meter: 63
after accept i get contact service....
Old 05-23-2012, 17:41   #3 (permalink)
-=whitezaNder=-'s Avatar
Member: 484671
Thanks Meter: 81
repair sd, write pm then unlock.....
goodluck!
Old 05-23-2012, 17:45   #4 (permalink)
contract's Avatar
Member: 671937
Sonork: 100.1613181
Thanks Meter: 94
Arrow
SIMLOCK invalid!
remove camera then give full bus check result...........
THANKS & BR
Old 05-23-2012, 18:16   #5 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
post full logs...and attached what exact unit)
Old 05-24-2012, 16:18   #6 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 35
SIMLOCK invalid! ---------
if you don't have full rpl
then
new rpl
Old 05-25-2012, 09:17   #7 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
no need rpl
f1st chek phone is bb5 sl1
and chek imei is ok
so just rapeir simlock with any tool
after this write good pm with supper SD outh and sd rapeir
all is ok
Old 05-25-2012, 10:09   #8 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Originally Posted by iftikhar_246 View Post
no need rpl
and chek imei is ok
all is ok
Yes, confirm, this is one Easy SL0 Nokia Phone, Use f/bus connection, go in SimLock tabulate and click in Repair, in this mode if the phone is just unlocked the SimLock Key is repaired.
For Dcc, or go in Rpl tabulate and Click in Restore Certificate From Server or Read Full Pm when Write Rf/bb From Server after the phone is Auth to Write SX4 or SuperSd Auth, Read all in Ceck/Bus and Phone is Repaired,
Old 05-25-2012, 15:59   #9 (permalink)
Member: 934255
Thanks Meter: 63
Done but dont work is a nokia 5130 sl3...
Old 05-25-2012, 19:30   #10 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. It's so hilarious, they all messed up with your phone but you didn't post full logs in 3 Days & only with edited logs, wasting there time & now showing your phone is SL3, better post full logs from next time for assistance, by the way your solution is return phone to customer.
Zuberchowdhry
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.20087 seconds with 9 queries
