05-05-2011, 12:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 681183 Status: Offline Thanks Meter: 165 | E72 Local Mode but not power on vibrate only (ANSWERED) i format the set then set goes in nokia hang condition i flash it with latest firmware version 054.005 after successful flash it only comes in local mode when i power on it only vibrate what should i do now |
05-05-2011, 12:16 | #3 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
flash with ufs3 after flash ui setting then format drives (user area) then post result | |
05-22-2011, 17:52 | #7 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Dubai Age: 39
Member: 617912 Status: Offline Thanks Meter: 41 | E72 Local Mode ok but not power on vibrate only sir i have e72 (RM-530) Comes with the problem of nokia hang condition i flash it with latest firmware version 054.005 after successful flash it only comes in local mode when i power on it only vibrate what should i do now |
05-22-2011, 17:54 | #8 (permalink) |
Member: 617912 Status: Offline Thanks Meter: 41 | MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] -******** Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.4.16.0, NTMP ver: 2.8.14.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 10C00214778803446E4B1F33F70CA2E8551DD48A ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 3.0 size: 0xC621C Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Original Imei: 35************ Original Product code: 0586765 Bluetooth ID: 6C9B02CBECEE SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone Type: RM-530 (Nokia E72-1) SW Version: V ICPR82_10w22.10.1 01-02-11 RM-530 (c) Nokia Imei plain: 35*********** Product Code: 0586765 Battery voltage: 4588 mV, current: 165 mA ApeCoreSw: 054.005 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35*********** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-22-2011, 18:03 | #9 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 956453 Status: Offline Thanks Meter: 141 | same like me i have 5 tool in repair nokia,but same problem. x5,x2......flashing finish,can localmode.......>>>>>but power on just vibra only..in normal mode ok in tool....but blank/dark display phone.remove cable put batre just vibra.....very very confuse... |
05-25-2012, 08:20 | #13 (permalink) | ||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
regards, | ||
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
