12-06-2010, 11:55 | #1 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 375673 Status: Offline Thanks Meter: 16 | Htc phoe100 unlock error plz help... i already hard reset but its d same Selected model: Shadow Set Security Policy ...Done. Reading Simlock data ... Running MemDump task ... Connected. Syncing from bkondisk.exe to dev:\ "bkondisk.exe"Copying (New) ... 0/21 k 21/21 k ok Connected. Syncing from dev:\simlock.bin to simlock Error: source pattern does not match a file: \simlock.bin Copy Failed Usage: CeCopy [options] Source_FileSpec Destination Options: /is Include same files /s Include subdirectories Arguments: Source_FileSpec File specification denoting the source of the copy. Destination Where files should be copied to. For the source, wild cards or directory names may be specifed, as may be single files. The destination can be either a directory or a file name, depending on the type of source specified. By default, an argument is assumed to live on a local filesystem. To indicate that either argument denotes a location on a device connected via ActiveSync, prepend 'dev:' to that argument. To articulate that a local filesystem is referenced, prepend 'desk:' to the argument. Exiting. error: bkondisk.log not found error: simlock.bin not found Simlock dump failed. |
12-06-2010, 12:10 | #2 (permalink) |
Member: 375673 Status: Offline Thanks Meter: 16 | THANKS FOR YOUR TIME OF READING MY TREAD HERE IS THE SOLUTION JUST TICK THE (SKIP HSPL) AND WHEN YOU PRESS THE CALCULATE LOOK AT PHONE IF IT ASKING ONLY SELECT YES 2 TYMES Selected model: Shadow Set Security Policy ...Done. Reading Simlock data ... Running MemDump task ... Connected. Syncing from bkondisk.exe to dev:\ "bkondisk.exe"Copying (New) ... 0/21 k 21/21 k ok CopyProcessMemoryToFile(00000042, b402709c, 00000010, simlock\docid.bin) Connected. Syncing from dev:\simlock.bin to simlock "simlock.bin"Copying (New) ... 0/256 k 64/256 k 128/256 k 192/256 k 256/256 k ok Simlock data dumped OK. Loading simlock.bin 0x20000... Loading docid.bin... ______________________________ IMEI: 3565220105xxxxxx CID: T-MOB010 OP: 20416 NCK: 67441678 ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ |
The Following User Says Thank You to jcjibz For This Useful Post: |
