05-14-2011, 08:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | HTI box firmware 00.07 and 00.08 can't ... (ANSWERED) i use firmware 00.07 still not good and now i update to 00.08 it still not good Pls check MXkey team. MXKEY Serial: [MxKey HTI FLASHER INTERFACE 3] - C......... Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.4.16.0, NTMP ver: 2.6.2.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Boot error: 00 00 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Last edited by 089999945; 05-14-2011 at 08:46. |
05-14-2011, 09:09 | #4 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote: it the same problem cant connect dct4 and bb5 and when close soft and then restart still not good. Pls check Mx-key team. thanks. | |
05-14-2011, 09:28 | #5 (permalink) | |
i use with this smar card driver HTI WinXP Smartcard Drivers V1 it still not good when i close my soft and then open again still have problem and can't connect with dct4 and bb5. pls hlep me. thnaks. | |
05-14-2011, 11:28 | #7 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote: i very try follow u is success but can't still connect or flash phone(with 3.4.2.0 or 3.4.2.1) for 3.5.00 i try is completed driver but when i click bus check or flash show like this and click no still show the same and click yes my soft restart and then it not connect all with HTI or No security dongle not detected show like this Pls fix it now HTIbox team. thanks. | |
05-14-2011, 12:32 | #8 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,259 | uninstall all and re install fresh installation and make sure u install drivers correctly and if needed manually in device manager , then update hti box and check restart make sure you unplug box from usb port and re plug in after installation and update. BR |
05-14-2011, 12:36 | #9 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144411 Status: Offline Sonork: 100.1593619 Thanks Meter: 60 | [QUOTE=089999945;7316504]i very try follow u is success but can't still connect or flash phone(with 3.4.2.0 or 3.4.2.1) for 3.5.00 i try is completed driver but when i click bus check or flash show like this This is a problem with USB cable use a good cable Ps: this happens always with J*/f, who need more power USE HTI |
05-15-2011, 02:47 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Aborting operation .. ok Thank you!!!!!!!!!! |
05-15-2011, 04:20 | #11 (permalink) | |
pls help me. thanks | |
05-15-2011, 10:30 | #12 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Now i can connect and flash some phone not all. thanks Manole. some phone show like this pls check it. thnaks. Last edited by 089999945; 05-15-2011 at 10:36. |
05-15-2011, 10:46 | #13 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | for N70 is ok Code: Version from phone: 5.0737.3.0.1 Version from file: 50737301.C0 MXKEY Serial: [MxKey HTI FLASHER INTERFACE 5] - Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.4.16.0, NTMP ver: 2.6.2.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35792700419216_BACK.rpl). APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 76D37E52A5587556375D04510F97D9DC0B99CF95 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 23900117EC70495137A8170F3237324F14FAFC6B ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 22FA - 0000 0011 [Samsung K8S6415ETA,64 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Processing MCU file: RM84_50737301.C0 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 Partitioning ...OK Erase size: 68.92 MB CMT NOR area [00000000-0052B515] erased in 46.750 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (Rap certificate3) sent APE KEYS block sent APE X-LOADER block sent APE PRIMAPP block sent APE SOS+LOADER block sent APE SOS+XZIP block sent APE PASUBTOC block sent APE PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (APE certificate3) sent APE SOS*CORE block sent Programming completed in 2 min 9.860 s Processing PPM file: RM84_50737301.V12 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 9.76 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100700, 17100701, 17100702, 17100703 Partitioning ...OK Erase size: 35.94 MB APE NAND area [01AE0000-02AFFFFF] erased in 0.078 s Flash programming ... Programming completed in 1 min 10.610 s Total time for flashing process(boot+erase+write) was 4 min 17.688 s Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35792700419216-0 Product Code: 0524129 Battery voltage: 4813 mV, current: 87 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357927004192160 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-15-2011, 11:06 | #14 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | 1 more with 1200 still the same problem Code: EM ID: 001531BF:DA3BDA66 ASIC type: 11 UEM Imei: 35573702035075 Flash Imei: 35573702035075 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35573702035075_BACK.rpl" Processing MCU file: rh99_05.060 [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001531BF:2984DA60 Area [01000000-0100FFFF] erased in 0.687 s Area [01010000-013AFFFF] erased in 35.156 s Area [013B0000-013EFFFF] erased in 2.969 s Area [017C0000-017EFFFF] erased in 0.062 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Programming completed in 21.703 s File Processed in 1 min 7.531 s Processing CNT file: rh990_nai5.06aa [DCT4,DCT4 ALGORITHM] size: 112.01 KB Supported Ids: 2292 ASIC ID: 0x0000 Device IO error: Access is denied (code: 5) |
05-15-2011, 11:34 | #15 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | I think all dct4 cant flash with this version y i say like this because i test alot dct4 it the same problem Pls check Mxbox team. Code: XKEY Serial: [MxKey HTI FLASHER INTERFACE 5] - Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.4.16.0, NTMP ver: 2.6.2.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Rpl backup already exist (C:\mobileEx\3.5\data\backup\35520203221676_BACK.rpl). Processing MCU file: rh112_003.100 [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0024446E:2984DA60 Area [01000000-0100FFFF] erased in 1.140 s Area [01010000-013AFFFF] erased in 1 min 5.547 s Area [013B0000-013EFFFF] erased in 4.735 s Area [017C0000-017EFFFF] erased in 0.062 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Programming completed in 14.844 s File Processed in 1 min 33.125 s Processing CNT file: rh1120_nai03.10mr [DCT4,DCT4 ALGORITHM] size: 110.44 KB Supported Ids: 2293 ASIC ID: 0x0000 Device IO error: Access is denied (code: 5) Code: forming Flash Authentication ...OK UEM ID: 0048118C:DA3BDA66 ASIC type: 11 UEM Imei: 35642402371345 Flash Imei: 35642402371345 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35642402371345_BACK.rpl" Processing MCU file: rh99_06.000 [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0048118C:2984DA60 Area [01000000-0100FFFF] erased in 0.610 s Area [01010000-013AFFFF] erased in 32.843 s Area [013B0000-013EFFFF] erased in 2.657 s Area [017C0000-017EFFFF] erased in 0.062 s Area [01FC0000-01FEFFFF] erased in 0.063 s Flash programming ... Programming completed in 21.547 s File Processed in 1 min 4.657 s Processing CNT file: rh990_nai6.00aa [DCT4,DCT4 ALGORITHM] size: 112.02 KB Supported Ids: 2292 ASIC ID: 0x0000 Device IO error: Access is denied (code: 5) |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
