09-10-2011, 07:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: chhattisgarh India
Member: 698592 Status: Offline Sonork: 100.1645954 Thanks Meter: 18 | Nokia 3110 contact service..not solve. SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302177506-0 Product code: 0514950 Battery voltage: 4860 mV, current: 53 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 359343021775060 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F after repair sim lock Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 Completed in 2.515 s RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-237_359343021775060_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 359343021775060 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 And can't be solved..any one pls do this a new problem..m trying to all method but not result. |
09-10-2011, 08:18 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Mate do according this procedure: 1_ Take backup of your RPL only NPC not All section 2_Reset all from Certificate tab but before you must had taken NPC backup 3_Write your NPC backup and the simlock rpl which is already calculated from server and saved in > C:\mobileEx\3.5\data\backup 4_Scan phone and see if still SL was damaged repair it 5_ Repair SD and write modified PM after PM Auth Your problem will be solved WBR |
09-10-2011, 11:05 | #5 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | @Rhyan and Chandan there is no server problem becuase Simlock Rpl is calculated from server Quote:
WBR | |
09-10-2011, 12:42 | #7 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Quote:
Why he can not repair? It is completely repairable don't confuse members with wrong answers WBR | |
09-10-2011, 17:39 | #8 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Please () fake post delete it Quote:
First write PM 1,309 using sx4 then I find a photograph in todays post http://forum.gsmhosting.com/vbb/7702314-post8.html follow it | |
09-10-2011, 17:50 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | First make backup rpl than (1)Repair sd (2)write full pm with sx4 dont skip lock aria rewrite lock aria (3)unlock with make init sim lock with tick on makeu sim lock rpl Your set will be done. |
