02-12-2014, 11:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Nokia 308 Flashing Completed But Set Dead MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C086D6ED Using device: USB ROM and HTI, FW ver: 00.50, SN: 01006630 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.115 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm838__08.13.mcusw [XG223,XG223_V0 ALG] size: 28.10 MB Supported Ids: 00000C2016100040 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 00000C201610004049B22109928EE9FC526DC300 [XGOLD 223] CMT PUBLIC ID: E08AF206235C345049B22109928EE9FC526DC300 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.43.0 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.43.0 revision: 4.0 size: 0x32350 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: FAF910DA218D8536CEFBDCE369A8C034160C6A5F Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 38.87 MB CMT FLASH,NOR area [40000000-4003FFFF] CMT FLASH,NOR area [47E00000-47E3FFFF] CMT FLASH,NOR area [400A0000-4251FFFF] CMT FLASH,NOR area [42520000-4261FFFF] CMT FLASH,NOR area [47E40000-47F1FFFF] Flash programming ... CMT ISSW block sent CMT MEMSET block sent CMT PRIMAPP block sent CMT LOADER block sent CMT PASUBTOC block sent CMT PAPUBKEYS: FAF910DA [] sent CMT UPDAPP block sent CMT MCUSW block sent Programming completed in 19.781 s Processing PPM file: rm838__08.13.ppm_maa [XG223,XG223_V0 ALG] size: 6.27 MB Supported Ids: 00000C2016100040 Erase size: 9.87 MB CMT FLASH,NOR area [42620000-42FFFFFF] erased in 0.016 s Flash programming ... Programming completed in 5.500 s Processing CNT file: rm838__08.13.image_maa_059N7V9_059S8L6_282_01 [XG223,XG223_V0 ALG] size: 51.50 MB Supported Ids: 00000C2016100040 Erase size: 78 MB CMT FLASH,NOR area [43000000-47DFFFFF] erased in 0.016 s Flash programming ... Programming completed in 31.110 s Total time for flashing process(boot+erase+write) was 1 min 3.578 s Waiting for device boot up ... Phone not found, retrying ... Any solution to get it back to life? |
02-12-2014, 14:13 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | I Think It's Internally Damage & Use Other Tool Same Issue? WBR. Arsalan gsm2000. |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
02-14-2014, 10:38 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Try to Flash it Downgrade Version & again with Latest, But looks Hardware issue. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
02-15-2014, 08:57 | #4 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
Fragga is right ZUBER is False........... You have no brave to say truth so you closed the post | |
02-15-2014, 09:05 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | MX-BOX IS HAVING BUG IN FLASHING SOME ASHA PHONES ALTHOUGH THE FLASHING GOES COMPLETE BUT STILL THE PHONES DEAD. U NEED TO FLASH WITH OTHER TOOLS TO MAKE PHONE ALIVE. HOPE MX-KEY TEAM WILL CHECK THIS BUG AS IT IS STILL EXIST IN CURRENT AND OLD SETUP. WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
