Old 01-22-2014, 04:13   #1 (permalink)
Member: 2110885
R9 work for SL3 cluster?
Hi everyone.
I have a SL3 cluster, this work with OCL hashcat i have 6 computers and i make 10 cods for day, the next month i goin to buy 10 computers more and 20 gpu, but im not sure if the amd R9 work with ocl hashcat
any idea?
Old 01-22-2014, 06:45   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
If you make 10 codes per day, then for sure you must know the answer of your question. If R9 cards are suitable to do SL3 bruteforce.
The Following User Says Thank You to debeliamark For This Useful Post:
Old 01-26-2014, 21:20   #3 (permalink)
Member: 2110885
yes but i read in another website about no work with hashcat any idea?
Old 01-27-2014, 06:57   #4 (permalink)
Member: 4627
Thanks Meter: 1,034
If you have some brain, then will not trust on anything just read. Buy a card ant test it itself.
Take a look over shot:
This is 1 x R9 290x on stock clocks, runing on SL3 BF - single Hawaii GPU core will give you 3,5 GHash / sec - amasing - like nearby 2 x 5870 ...
What is hard to make here?
WBR, DebeliaMark, Bulgaria
P.S. 40 x R9 290x will bring you 1 SL3 code per hour ( on stock clocks !!! ) evenmore this card is veeery good for tuning - so - probably you can achieve a 1 hour codeback with 32 - 35 x R9 290x in cluster!
P.S.2 - R9 is so expensive to make SL3 BF - it cost near 500 euro, so in oposite side good "old" 5970 will give you SAME calculation power for 150 euro ( on second hand !!! ) ... mean - there no idea to use this ( R9 290x ) graphics card still for BruteForce.
Old 01-28-2014, 06:51   #5 (permalink)
Member: 2110885
we have:
10: 7970 saphire
1: devil 13 (a bad seller -_- this was buy for my boss)
1: 5990
is soo hard buy used video card you know sometime no work and very much problems.
the cost for the r9 i find $420 USD
and 7990 $380
and i ask for the r9 here because i dont use before the r9 and if the ocl hashcat 0.09 work with this card.
anyway, thanks
Old 02-01-2014, 06:35   #6 (permalink)
Member: 4627
Thanks Meter: 1,034
we have:
10: 7970 saphire
1: 5990
and 7990 $380
anyway, thanks
I can offer you 40 PCS of used 5970 - all in perfect working condition + watercooling ( new ) if you like ( 120 euro per pcs ) ...
Old 02-01-2014, 14:35   #7 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
we have:
10: 7970 saphire
1: 5990
and 7990 $380
anyway, thanks
oclhashcat-lite 0.9 not working with new R9 290x cards for all this you need use oclhashcat 1.0 and this ocl not work with any cloud server now then you will need play with it no easy job. If need only for sl3 and power cost is not a problem better buy from other users 5970 used becosue with new card R9 will got much problem to run all in cloud like MSM or other.
About speed R9 290x is this with Uber mode or with silence mode and you use latest 13.12 drivers becosue I think this is little to slow speed that I think.
In cgminer I see speed 1mhash/s and speed in sl3 I see same like 7970 with 1.1ghz core speed and this is not correct i think should be 36% faster.
Old 02-02-2014, 17:34   #8 (permalink)
Member: 2110885
You know the name of any SL3 cluster?
how much work de R9 270x?
Old 02-19-2014, 01:16   #9 (permalink)
Nonoyxp's Avatar
Member: 141973
Sonork: 100.1579084
Thanks Meter: 4,002
guys can you share how to work with r9 290x? TIA
Old 03-05-2014, 00:36   #10 (permalink)
Member: 2110885
no idea :/ i with the same problem
Old 05-13-2022, 12:34   #11 (permalink)
Member: 196365
Thanks Meter: 35
Anyone can share oclhashcat 1.0 so I can use with R9 290x ?
Thanks in advance
Old 05-13-2022, 14:01   #12 (permalink)
Member: 196365
Thanks Meter: 35
What command to use with oclhashcat 1.0 ?
Old command doesn't work with oclhashcat 1.0 :-(
any help please?
Page generated in 0.26989 seconds with 9 queries
