03-06-2012, 10:55 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: kushtia_BANGLADESH
Member: 1002743 Status: Offline Sonork: [email protected] Thanks Meter: 24 | i fase a problem in 1.8 ver not work pmm auth optionl (ANSWERED) NK module version: 1.21 NK applet version: 00.20 NK module ready. Market items is empty, please select the correct products path ! Please "Scan" or "BUS check" before any operation ... STANDALONE MODE enabled. Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...No route to host Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...No route to host Retrying ... SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...No route to host Connecting to server[main.mxkey.biz] ...No route to host Connecting to server[main.mxkey.biz] ...No route to host Retrying ... SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...No route to host Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...No route to host |
03-06-2012, 11:04 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. no need pmm auth as HTI box standalone and server offline. so do super sd auth & repair sd instead of pmm auth with untick rr/bb on all function if ask. have a good day. |
03-07-2012, 08:49 | #4 (permalink) | |
Junior Member Join Date: Sep 2011 Location: Indonesia Raya
Member: 1664657 Status: Offline Sonork: 100.1608125 Thanks Meter: 1 | Quote:
how do i solve this problem: Phone type: RM-84 (Nokia N70) SW version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. ApeCoreSw: V 5.0737.3.0.1 Imei plain: 35808001678819-2 Product code: 0534654 Battery voltage: 3910 mV, current: 82 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Security code: 12345 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358080016788192 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Latest software release for Nokia N70 is 5.0737.3.0.1 i have do following action 1.backed up full rpl 2.backed up full pm 3.erase flash with untick safe erase option 4.reflashing phone 5.restore rpl 6.write pm back up 7.super sd auth 8.ui phone still SECURITY_TEST failed! how do i solve SECURITY_TEST failed! without pmm auth please give me step by step solution.... | |
03-15-2012, 09:29 | #6 (permalink) |
Member: 1002743 Status: Offline Sonork: [email protected] Thanks Meter: 24 | try bro all ok but security tast fail not gon and my set some time auto off tell me how to slove this problem |
03-15-2012, 10:18 | #8 (permalink) | |
Member: 1002743 Status: Offline Sonork: [email protected] Thanks Meter: 24 | Quote:
SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196303253629-8 Product code: 0550691 Battery voltage: 3821 mV, current: 105 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351963032536298 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN and self test security FALIED(1) | |
03-15-2012, 10:21 | #9 (permalink) |
Member: 1002743 Status: Offline Sonork: [email protected] Thanks Meter: 24 | |
03-17-2012, 07:58 | #11 (permalink) |
03-17-2012, 08:08 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. no reason but when all solution fails, then do this solution already posted before: http://forum.gsmhosting.com/vbb/f550...7/#post8221272 do this procedure carefully & step by step. 1. backup rpl: go > imei and security tab > imei rebuild > backup rpl 2. erase pm: go > pm tab > erase pm 3. reset npc data: go> imei and security tab> reset NPC data ( backup rpl before ) 4. erase pm again: go > pm tab > erase pm 5. Write rpl from backup: go > imei and security tab > imei rebuild > restore imei 6. go pm tab > super sd auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again: go > pm tab > erase pm 8. recover CERT: go>imei and security tab> imei rebuild > recover cert 9. do full factory reset & enjoy. phone will be come back from security test failed its a last & 100% working solution from my point of view. have a good day. br, zuberchowdhry |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
03-17-2012, 10:36 | #14 (permalink) | |
not work log Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196303253629-8 Product code: 0514950 Battery voltage: 3889 mV, current: 81 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351963032536298 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F | |
03-17-2012, 10:45 | #15 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. one more option, go to simlock & do update splock, then after load full pm & write only 1 & 309. can do the job. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
