01-24-2010, 03:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | i have only UFS http://forum.gsmhosting.com/vbb/show...&postcount=182 http://forum.gsmhosting.com/vbb/show...&postcount=188 http://forum.gsmhosting.com/vbb/show...&postcount=189 http://forum.gsmhosting.com/vbb/show...&postcount=195 i dont have any interface only ufs.. br |
01-24-2010, 03:40 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Tnx for reporting this. We will see what can be done. BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
01-24-2010, 05:14 | #5 (permalink) |
Freak Poster Join Date: Jan 2004 Location: philippines
Member: 49854 Status: Offline Sonork: 100.1652592 Thanks Meter: 38 | mine too when i insert my ufs it always ask for box driver after installing the driver and opening it again ask for box driver how do you solve this... |
01-24-2010, 21:52 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | try update partian module, and post report here Quote:
br, | |
The Following User Says Thank You to Andra For This Useful Post: |
01-25-2010, 02:09 | #11 (permalink) |
Junior Member Join Date: Dec 2007
Member: 650319 Status: Offline Thanks Meter: 16 | Hii mxkey team, about "BootLoader not responding, mostly RAM problem !" when we use UFS interface, It will be ok if I run mobilex DCT4 nokia service tool and waiting about 20 minutes,don't let it go run activity, bus check is ok, flashing is ok, other services is ok. Please check and fix if you finded the bug. look my log : Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11826, Date: 22-01-2010 ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D6ABD9:2984DA60 ASIC type: 2 UEM Imei: 04414601779 Flash Imei: 04414601779 MasterCode: 6364555147 RPL saved to "C:\mobileEx\3.3\data\backup\04414601779_BACK. rpl" Phone Type: RH-46 (Nokia Wanda) SW Version: V J190V0600.nep 17-09-04 RH-46 (c)NMP Esn plain: 04414601779 Esn OTP: 04414601779 Product Code: 0512995 Cellular System: CDMA ASIC ID: 0x1130, type: 2 Ppm Id: L Language Pack: Indonesia,English,Chinese Simpl.,Chinese Trad. We're waiting for next revision as soon as posible, I hope mxkey will be powerfull tool and not dead project ofcourse...he..he..be solid team... best regards. |
The Following User Says Thank You to hendiek For This Useful Post: |
01-25-2010, 03:53 | #12 (permalink) |
Member: 757799 Status: Offline Thanks Meter: 782 | module is updated only in dct4 face the error Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11826, Date: 22-01-2010 ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 [SIZE=1][COLOR=#ff0000]BootLoader not responding, mostly RAM problem ! on bb5 ok now Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11826, Date: 22-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 204001078E9F0254A10A8BD75D1A13D4E740351F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B Original Imei: 35366201019426 Original Product code: 0563658 Bluetooth ID: 0021ABE4900E Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 04.00 13-06-08 RM-411 (c) Nokia Imei plain: 35366201019426-4 Product Code: 0563658 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353662010194264 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Last edited by trio1; 01-25-2010 at 03:59. |
01-25-2010, 04:33 | #13 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | after update it ask for sign application AGAIN, how many times we can sign? 5 times in each version or.... Code: Please 'Sign Application' first, make sure you have correct date,time setting on your computer. Every card have 5 chances to request digital signature from server. |
01-25-2010, 05:31 | #14 (permalink) | |
Member: 172261 Status: Offline Thanks Meter: 364 | Quote:
again with this error after update | |
01-25-2010, 08:58 | #15 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
how can it be driver problem ... | |
i have a ufs 3 flasher | dapinderjit | UFS2 + UFS3-Tornadoflasher | 0 | 12-21-2008 16:55 |
****today's need of multiple devices is only ufs-pro**** **** | HAROON's | UFS - Pro | 1 | 06-23-2007 11:26 |
==T290 Shows Battery sign ONLY-UFS Full Flash- No change== | blaiseid | Sony Ericsson | 9 | 12-29-2005 17:20 |
