12-31-2009, 09:38 | #1 (permalink) |
Banned Join Date: Feb 2007
Member: 445578 Status: Offline Thanks Meter: 440 | Imei is ok but superdongle key invalid can be repaired??? Library version: 1.0.0.11446, Date: 25-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 08E00115BEE37B5635E3E43FDDC916318B6EF252 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 0041 - 0000 6A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Original Imei: 35641502604523 Original Product code: 0537684 Bluetooth ID: 002266C57AFB Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35641502604523-7 Product Code: 0537684 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed "RM-217" folder created. Imei net: 356415026045237 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Last edited by sumon.bd; 12-31-2009 at 09:47. |
12-31-2009, 09:46 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | yes its possible but not in mxkey but u need MT or UB & need some cradits also |
The Following 2 Users Say Thank You to sneha For This Useful Post: |
12-31-2009, 09:52 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | u need MT or UB & need some cradits also SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. |
The Following User Says Thank You to FEATURE GSM™ For This Useful Post: |
nokia 6280 numeric key pad ic print is ok but frornt panel keypad ic print is broken | Matwala | Nokia Hardware & Hardware Repair | 2 | 07-22-2012 08:09 |
5800d rm-356 superdongle key invalid and security test failed ok.... | mesut07 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-13-2010 19:40 |
superdongle key invalid repair using mx key | sajidashraf | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 01-25-2010 19:44 |
n-70 superdongle key invalid | nagendra_20061 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 08-31-2009 21:31 |
