04-11-2013, 17:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223166 Status: Offline Thanks Meter: 14 | Nokia 302 dead after read ID CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: B21C0000FFFB3C40100731A604F6385E3C363924 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. ERROR: Loader not responding ! And never turn on the phone again. I have tries remove battery, turn into again. Flash give me same error, Any help?? Thanks |
04-15-2013, 18:43 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, there is no way to kill the phone upon read sha. there was no flash write process. well, i'm sorry for you, maybe it's your bad day. please post FULL Buscheck logs do not cut logs or edit anything. BR |
04-16-2013, 15:16 | #6 (permalink) | |
Member: 223166 Status: Offline Thanks Meter: 14 | Quote:
I have turned off the computer... | |
05-17-2013, 16:11 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | here is mine Asha 302 RM-813 v14.78 i want to change languague by flashing V14.92 but after i just press "Check" button i have and error message at the end of log file. now i remove battery and power on nothing happen totally dead. how to solve it? i didn't write anything yet. phone is knew. here is log file: Quote:
05-17-2013, 18:29 | #9 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Try to Sync Files with Synchronize Files Button on Mxkey Apps., Then Flash Phone will be solve it, Till this time, we will check what's wrong, Please report & reply of the result from above process. BR, ZUBER | |
05-18-2013, 00:31 | #10 (permalink) | |
Member: 118601 Status: Offline Thanks Meter: 200 | Please sir i synchronise files but unfortunately because of my low internet connection,all files can't be update after many try, so i decide to try with phone then connect it and press "check" and phone boot and display start blinking but phone can't power on, so i decide to flash anyway,after flash finish,phone just power on and then off, restart and never full power on, now if i success full update synchronise files and reflash phone can it solve my problem? here is full log of flashing Quote:
05-18-2013, 10:19 | #12 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | Hello sir i try to do as you said (Do Super SD Auth & Repair SD) but can't success. where is the backup rpl i should write manually? what i see is this ( RPL saved to "C:\mobileEx\3.5\data\backup\BB5_3563350516113 1_CE RT.rpl" ) save during flashing phone. should i read PM form another working phone and write here to solve problem simlock not valid? please give me steps by steps procedure with the soft 3.5 rev2.6 here is log what scan give now after i do waht you said. Phone type: RM-813 (Nokia 302) SW version: V 14.92 09-11-12 RM-813 (c) Nokia Imei plain: 35633505161131-7 Battery voltage: 4153 mV, current: 165 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: 01035602XXXXXX, ver: SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C085E944 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010030B4 Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Phone type: RM-813 (Nokia 302) SW version: V 14.92 09-11-12 RM-813 (c) Nokia Using cached productData. PUBLIC ID: 18520000FFFB3C40CD1ED285687457AABFB16298 PRIVATE ID: A52A73D7978010E21EC554BFB209667796B069F8 SUPERDONGLE authorized ! MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C085E944 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010030B4 Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Phone type: RM-813 (Nokia 302) SW version: V 14.92 09-11-12 RM-813 (c) Nokia Using cached productData. PUBLIC ID: 18520000FFFB3C40CD1ED285687457AABFB16298 PRIVATE ID: A52A73D7978010E21EC554BFB209667796B069F8 Completed in 0.141 s Updating SUPERDONGLE_KEY ...OK Now you can write RFBB/PM data to the phone. Done. |
05-19-2013, 05:33 | #14 (permalink) | |
Member: 118601 Status: Offline Thanks Meter: 200 | please Sir as you can see,my IMEI don't have any problem now, the problem is about SIMLOCK_DATA corrupted and SIMLOCK invalid! when i scan phone, anyway,i try restore IMEI and write manual rpl but the result it the same as you can see the log down, Quote:
05-19-2013, 06:19 | #15 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | here is all files i backup on phone after flashing as nothing was backup before it dead just when i press "check" here is link Download 302 RM-813 full backup.rar |
