04-20-2011, 16:50 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Ukraine Age: 47
Member: 167592 Status: Offline Thanks Meter: 29 | install problem 3.4_2.0 All older MXKey version work good. I try to install new version 3.4_2.0, and I have error Plz help to solved this problem |
04-21-2011, 11:17 | #8 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | uninstall first all previous versions of mx-key , also need to erase mobileex folder from c:/ drive . ( but remember first backup d folder named "data") after that isntall mx-key main setup v3.4 rev2.0 , restore data folder where it was . then check |
04-21-2011, 11:29 | #10 (permalink) | |
Member: 167592 Status: Offline Thanks Meter: 29 | Quote:
That way I did, but nothing helped, I also cleaned registry (*regedit* I clear all *mobileEx*) all previous versions installed without any problems, I downloaded the installer itself several times from different sources. What could be the problem here? | |
04-21-2011, 11:37 | #11 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
this may be virus in ur system...... ACCESS VIOLATION is virus problem.... Uninstall mxkey delete the folder contents from mxkey...... Clean the virus and install latest setup............ Scan with trojan remover from simplysup.com | |
04-21-2011, 19:32 | #14 (permalink) |
Member: 167592 Status: Offline Thanks Meter: 29 | I solved the problem on my computers; 1. Remove previous mobileEx version and delete the folder mobileEx 2. Disable Startup Tss Instrument API tray utility 3. temporarily remove or rename root.exe from the directory C: \ Program Files \ Common Files \ Nokia \ Tss \ Instrument API \ bin\ 4. setup mobileEx_setup_v3.4_rev2.0 5. after setup mobileEx restore root.exe Good luck! |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
