10-12-2009, 02:02 | #1 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1077162 Status: Offline Thanks Meter: 171 | New "mxkey update v3.2 revision 5.3 and 5.4" Discuss here: v3.2 revision 5.3, Public-Release |
The Following 32 Users Say Thank You to ali-xander™ For This Useful Post: |
10-12-2009, 02:06 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | v3.2 revision 5.3, Public-Release testing on the way... i'll post result later.... br. |
The Following User Says Thank You to rico_deep For This Useful Post: |
10-12-2009, 03:22 | #3 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | Quote:
The Following 2 Users Say Thank You to ru_dee For This Useful Post: |
10-12-2009, 04:08 | #4 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Quote:
Now one can write protected 308 field (simlock data) from nokia rpl (ask2rpl) with mx-key.. but about writing full backup (taken by mx-key) still its not clear... Hope someone tests it... | |
10-12-2009, 06:01 | #6 (permalink) |
Product Manager Join Date: Apr 2009 Location: BD,BH,CN
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Thanks............ please Downloads adds br, gsm_yousuf |
The Following User Says Thank You to UNLOCK PARK ® For This Useful Post: |
10-12-2009, 06:34 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | update ? we are waiting for some big update restore SUPER DONGLE KEY for valid rpl backup |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
10-12-2009, 06:42 | #9 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Minor update - MAIN Fixed, Windows Vista & Windows 7 compability. - NK Fixed, BB5 SIMLOCK_DATA/KEY PA_SL3 write Fixed, BB5 RAPU-YAMA phones flashing Fixed, DCT4 flashing bug(DEAD after flash/unlock) agin miner release will be upload |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
10-12-2009, 06:47 | #10 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | MobieX 3.2 rev, 5.3 WD2 Flash Unlock tested WD2 : NHL-8 3650 PPM Flashing still error same with previous version Hereith log: Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1] SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x1058 Supported Ids: 0082 FlashID0: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: w2_amd.fia [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7168 Supported Ids: 0082 Performing Flash Authentication ...OK UEM ID: 0085F8DE:2984DA7E ASIC type: 5 UEM Imei: 35110260257934 Flash Imei: 35110260257934 RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35110260257934_BA CK.rpl" Processing file: Nhl83041.7C1 as MCU [WD2 BT2,WD2 ALGORITHM,WD2 CBUS BT] size: 18.07 MB Supported Ids: 0082, 1081 ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1] SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x1058 Supported Ids: 0082 FlashID0: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: w2_amd.fia [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7168 Supported Ids: 0082 Performing Flash Authentication ...OK UEM ID: 0085F8DE:2984DA7E Algorithm: w2_cbusb.fia [WD2 CBUS BT] version: 4.70.1 revision: 0.7 size: 0x25 Supported Ids: 0082 Area [00000000-0000FFFF] erased in 0.703 s Area [00010000-006FFFFF] erased in 1 min 13.406 s Area [02000000-023FFFFF] erased in 39.672 s Area [04000000-046DDFFF] erased in 1 min 16.828 s Flash programming ... BT MCM image (0x21): 0002DD00 Programming BT image ... BT image written. Programming completed in 3 min 54.640 s File Processed in 7 min 28.188 s Processing file: Nhl83041.732 as PPM [WD2 BT2,WD2 ALGORITHM] size: 1.22 MB Supported Ids: 0082, 1081 ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1] SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x1058 Supported Ids: 0082 FlashID0: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Algorithm: w2_amd.fia [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7168 Supported Ids: 0082 Performing Flash Authentication ...OK UEM ID: 0085F8DE:2984DA7E Area [00000000-0000FFFF] erased in 0.656 s Area [04730000-047FFFFF] erased in 9.500 s Area [00700000-00758FFE] erased in 3.922 s Flash programming ... Error while programming [14] at 0x04748000, Result: 0872 Flashing terminated with error(s) in 8 min 35.281 s RX Buffer: 0872 |
The Following User Says Thank You to abellcell For This Useful Post: |
10-12-2009, 08:52 | #15 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | Hello To ALL. at last mx-key did it.................. and this time first in world MX-KEY Cheap But its Better From Expensive Tool (proved) Here is the Log of 5130c SL3 RPL WRITING. Before Version Info: MCU SW version: V 06.94 21-07-09 RM-495 (c) Nokia HW version: 1000 RFIC version: 06540601 DSP version: ICPR72_09w04 LCD version: SEIKO PPM version: V 06.94 21-07-09 RM-495 (c) Nokia EN BT MCM version: 2222-143C Retu version: 16 Tahvo version: 22 Content Pack version: Content: en_blu V 06.94 21-07-09 RM-495 (c) Nokia Product Info: Production serial number: HED151226 Product code: 0571593 Module code: 0204024 Basic production code: 0567772 Long production SN: 0 Serial Numbers: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 41 F2 Other Info: Model : Nokia 5130c-2 (Classic Phone) BSI: 4.2 KOhm SIMLOCK_DATA corrupted! Nokia ORIGINAL RPL WRITING LOGS.... Imei: 35417903096451 Updating SIMLOCK...OK Updating SUPERDONGLE_KEY ...OK Updating CMLA_KEY...OK Updating WMDRM_PD...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 1E1002021FA77D56C560FD93885271D466FEAF22 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35417903096451-8 Product Code: 0571593 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid manual erase to this phone ! TimeStamp: 2009-07-28T03:55:51Z SW Version: 06.94 Variant Version: 010 ProductProfile: RM495_0571593_06.94_010.spr Simlock: 0571593_simlock.bin Imei: 354179030964518 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Best Regard's & Wish u all the Best In Feature. Bluffmaster |
The Following 20 Users Say Thank You to bluffmaster For This Useful Post: |
v3.2 revision 1.3, Public-Release NEW UPDATE:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 06-13-2009 06:52 |
