Old 01-19-2010, 18:35   #1 (permalink)
SinghForHelp's Avatar
Member: 451538
Thanks Meter: 98
Invalid account
plz tell me the solution
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0A70020AAA087D56CC55CEF748408C29BC534FBE
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Reading RAP NPC (0x168 bytes)
Begin Certificate Request ...
Connecting to server ...OK, Login ...
Invalid account.
ERROR: No certificate found in the database !
The Following User Says Thank You to SinghForHelp For This Useful Post:
Old 01-19-2010, 19:14   #2 (permalink)
.::PATEL TELECOM::.'s Avatar
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
i have same problem i can't use "recover certificate"
please explain me how to use this function
thanks
Patel telecom
Old 01-20-2010, 01:09   #3 (permalink)
Member: 451538
Thanks Meter: 98
MANOLE can tell us. if he is not too busy
Old 01-20-2010, 05:45   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
~ This will make restore CCC,HWC or VARIANT by product code from server database.
Button located to [IMEI & Security->Recover CERT]
perhaps readed carefully in
C:\mobileEx\3.3\changes.txt
CCC,HWC or VARIANT is part of CMT Certificate data
like this one
[CERT_PROG_DATA_OUT_CMT]
NPC_DATA_1=CBFC673F000041500000000000000000000000000000000000000000303534333630344300000000
NPC_DATA_2=0000000000000000000000003346E09490984146AC8E0E0000000000000000001AF00110D0440058
NPC_DATA_3=BD9547DBAA04F6C6BA7386F63D66090E94F3701646DA91CCD35BBAC22E5CBF73C603D4C909535CFA
NPC_DATA_4=A7B890A40CC7728DA3A45E02000000000000000000000000000000000200000047534D0000000000
NPC_DATA_5=3335690401494406FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000
NPC_DATA_6=2EFC9F161A00000000000000000000000000000000000000000000000000000035098B628766ED28
NPC_DATA_7=E1D450FCB949791BC797CCD54D0A933779C548B61F1C215FFBBFD21CA2E740804B5737C5C836C441
NPC_DATA_8=750C7919AE96284323E887C45DA987AF145E9DE52E885711A30BC687520AC4F8A3E51D56258ED1AB
NPC_DATA_9=9C5F3CC425EE584FDFAAF835E624E2F2F13E8BA8C3DF83E70F2DBC0F7CF3D143B84B65C6475AEC30
CCC_DATA_1=4343434302004150010000009138E0940689FE451E622A00328299000000600100000000E37EFE45
CCC_DATA_2=00000000000000000000000000000000000000000000000000000000000000003035343336303443
CCC_DATA_3=E37EFE450000000000000000030000000F0000000100000000000000000000000000000000000000
CCC_DATA_4=00000000000000000000000000000000000000000000000000000000000000000000000000000000
CCC_DATA_5=00000000000000000000000000000000000000000000000000000000000000000000000000000000
CCC_DATA_6=000000000000000000000000000000000000000000000000B1E4DEB62AF18FA797AE3298B376E659
CCC_DATA_7=4A87C2948FDBF1C91A759E88B8427569A906A96656F636943839E8FA9EEF49D100320D538EDF8656
CCC_DATA_8=720FC080888089B41767A56723CBDDE663AD2BBD5BDC1954E9D04A15891D41BE08417F2A644C4E7A
CCC_DATA_9=1042D7A1C9254544E91AFD31962DFCCDF19E3E0E76E258CCD506C4AAA8664478
HWC_DATA_1=4348574305004150010000003346E09491984146AF8E0E0000000000000000000000000000000000
HWC_DATA_2=00000000000000001AF00110D0440058BD9547DBAA04F6C6BA7386F6303534333630344300000000
HWC_DATA_3=00000000104EB966792AB1495529CC4EB9CC0B549104E01830793DCE2CCA5FC375CE772E2453287B
HWC_DATA_4=6310DFF2107D1B8D0CC0C637B26298B51F644A9B3E2BB592C5110C585E6188DFBAD94B3856126767
HWC_DATA_5=4ED88E84494C0B97ECF5604003384ACCB4C5D9763E166FE637723FD12667509F434002E5EF2FFB77
HWC_DATA_6=75817270F87D71066D87151A
if CCC or WHC data missing phone have Contact retailer condition.
do sx-4 many time but still have
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed
but in one condition .
not for recovery damage NPC data / IMEI .
br,
Old 01-23-2010, 15:14   #5 (permalink)
Member: 451538
Thanks Meter: 98
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35196203214405-3
Product Code: 0514950
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 351962032144053
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 01-24-2010, 00:29   #6 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
write pm with sx4 problem solv
Furious-gold Invalid Account Problem ROUGHNECK FuriousGold 1 05-05-2008 22:49
invalid account banwait FuriouS II 1 03-12-2007 08:53
Bad License and invalid account 7ZARK7 FuriouS II 1 04-09-2006 04:11
Page generated in 0.17226 seconds with 10 queries
