09-14-2010, 03:50 | #4 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 721785 Status: Offline Thanks Meter: 29 | I do not know if i have the same problem ! But when i want to unlock soft say : Code: Imei net: 01186900330xxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 9999900017382363 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 73404F BLOCK 2: 1.LOCKED (MCC+MNC): 740FFF BLOCK 3: 1.LOCKED (MCC+MNC): 732123 BLOCK 4: 1.LOCKED (MCC+MNC): 71606F BLOCK 5: 1.LOCKED (MCC+MNC): 21407F BLOCK 6: 1.LOCKED (MCC+MNC): 21402F BLOCK 7: 1.LOCKED (MCC+MNC): 73002F BLOCK 8: 1.LOCKED (MCC+MNC): 72207F BLOCK 9: 1.LOCKED (MCC+MNC): 74807F BLOCK 10: 1.LOCKED (MCC+MNC): 33403F BLOCK 11: 1.LOCKED (MCC+MNC): 70403F BLOCK 12: 1.LOCKED (MCC+MNC): 70604F BLOCK 13: 1.LOCKED (MCC+MNC): 71030F BLOCK 14: 1.LOCKED (MCC+MNC): 71402F Calculating SIMLOCK RPL using security server ... Serial: xxxxxxxxx FW version: 00.20 Counter remain: 98.52% Licenses: 0 = True 1 = True 2 = True DCT4PLUS License: True - Registered to: yor21 |
09-14-2010, 04:00 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | did you execute it correctly? DCT4 > Imei & Security > Locks : Init simlock, mark direct unlock (RSA method, full unlock), or un-mark for old method (certain firmware version supported patch, standalone) |
09-14-2010, 04:11 | #6 (permalink) |
Member: 721785 Status: Offline Thanks Meter: 29 | I did check : I'm working versio 3.4 (re1.2) Direct Unlock Init simlock ---- Still same !!! PD: Even when i try to enter to the SUPPORT nothing happen , I believe SUPPORT is working fine , but i can not getting in to it ..... Last edited by yor21; 09-14-2010 at 04:20. |
09-14-2010, 04:34 | #8 (permalink) |
Member: 721785 Status: Offline Thanks Meter: 29 | My friend, all did fine !! Code: Imei net: 011xxxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 9999900017382363 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 73404F BLOCK 2: 1.LOCKED (MCC+MNC): 740FFF BLOCK 3: 1.LOCKED (MCC+MNC): 732123 BLOCK 4: 1.LOCKED (MCC+MNC): 71606F BLOCK 5: 1.LOCKED (MCC+MNC): 21407F BLOCK 6: 1.LOCKED (MCC+MNC): 21402F BLOCK 7: 1.LOCKED (MCC+MNC): 73002F BLOCK 8: 1.LOCKED (MCC+MNC): 72207F BLOCK 9: 1.LOCKED (MCC+MNC): 74807F BLOCK 10: 1.LOCKED (MCC+MNC): 33403F BLOCK 11: 1.LOCKED (MCC+MNC): 70403F BLOCK 12: 1.LOCKED (MCC+MNC): 70604F BLOCK 13: 1.LOCKED (MCC+MNC): 71030F BLOCK 14: 1.LOCKED (MCC+MNC): 71402F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.1 [CR1]DCT4PLUS remaining credit: 38 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-513_0118xxxxxxxxx_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 0118xxxxxxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
