Old 04-13-2010, 12:29   #1 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Thanks Meter: 232
ERROR: could not calculate data wrong response from server !
All Who Have problem In 1661.
Calculating SIMLOCK RPL using security server ...ERROR: could not calculate data, wrong
1:Flash ur Phone To Letest Version 5.01.
2:Write Attach Pm File To Phone.
3:Use Unlock/Repair Metode.
All Will Ok...!
MxKey Rocks
Tested.
Imei net: 35831103992957
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
Calculating SIMLOCK RPL using security server ...OK
RPL saved to "C:\mobileEx\3.3\data\backup\RH-122_35831103992957_SIM.RPL"
Updating SIMLOCK ...OK
Reading Simlock info ...
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
If Still Problem Post Logs Here.
The Following User Says Thank You to UNIQUEM For This Useful Post:
Old 04-13-2010, 13:34   #2 (permalink)
Member: 42604
Thanks Meter: 187
Got same problem...
Calculating SIMLOCK RPL using security server ...ERROR: could not calculate data, wrong response from server !
my version is already 5.01..
try this PM and post result later...
Old 04-13-2010, 13:52   #3 (permalink)
Member: 42604
Thanks Meter: 187
After writing attached PM...samme problem..
Old 04-13-2010, 14:02   #4 (permalink)
GSMunlockvilla's Avatar
Member: 1022742
Thanks Meter: 187
No need flashing cos i had same problem but now all is ok no need flashing tested many phones
regards
Old 04-13-2010, 14:07   #5 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I guess it's due to server overload,try later you'll get your phone unlocked.
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Nokia GID 1 + 2 calculator Nokia man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-24-1999 08:42
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.20536 seconds with 10 queries
