12-23-2009, 08:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: My Lappy Age: 37
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | log in I Have A Problem. is there log in problem WITH IMEI? JUST CHECK THIS INFO ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0085DB90A3BDA66 ASIC type: 11 UEM Imei: 35984501728833 Connecting to server ...OK, Login ... دËr• BECUASE WHENVER I WNAT TO MAKE IMEI I JUST GOT THIS MESSAGE SINCE AFTER DAY YESTERDAY. THANKS!!!!!!!!!!!1 SHEIKH |
12-23-2009, 08:25 | #2 (permalink) |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | 2nd og IS SECOND LOG ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009C4139:2984DA60 ASIC type: 2 UEM Imei: 35395101422437 Connecting to server ...OK, Login ... Hello C0802A26, you have 790 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35395101422437.RP L" ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009C4139:2984DA60 Programming FLASH Imei ...failed Phone Type: RH-64 SW Version: V 6.00 24-10-06 RH-64 (c) NMP Imei plain: ??????????????-? Product Code: 0525392 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: English,Hindi,Marathi Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 6A66B42FF09B8E95 PROFILE_BITS: 10AB547C0C00A96F JUST GIVE INFO BECAUSE I AM IN VERY TENSION. THANKS!!!!!! SHEIKH |
Bomb!!Bomb!!!OCTOPUS box ,Martech key ,UB logs,Setool logs ,Genie logs in promotion | victor-in-gsm | Main Sales Section | 0 | 11-24-2009 08:50 |
[14-07-2008] SMTi LOG in Stock & New Cruiser A2 LOG Prices :) | UnlockBase.com | UnlockBase | 3 | 08-21-2008 02:00 |
can't log-in in support | giero | FuriousGold | 0 | 07-10-2008 03:30 |
can't log in in support area | chowdary | Infinity-Box | 3 | 04-27-2005 12:18 |
