02-04-2010, 08:33 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: philippines
Member: 529534 Status: Offline Thanks Meter: 38 | MANOLE give us video on security test failed procedure done already your two ways but unsuccessfully repaired the phone can u give us VIDEO sir MANOLE on how to resolve this problem |
The Following 2 Users Say Thank You to mrcellphone For This Useful Post: |
02-04-2010, 11:23 | #13 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | security test failed procedure Quote:
JUST FOLLOW THIS STEPS If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 Br, akashub | |
The Following User Says Thank You to akashub For This Useful Post: |
02-04-2010, 14:26 | #14 (permalink) | |
Crazy Poster Join Date: Feb 2010
Member: 1226388 Status: Offline Sonork: jk khan Thanks Meter: 13 | Quote:
First test and advice others to follow. | |
The Following User Says Thank You to gsm_telangana For This Useful Post: |
02-04-2010, 14:31 | #15 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Imei: 35521203706511 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0570010849E07C564CF114C5C6E248704F61D839 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35521203706511-9 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! TimeStamp: 2009-11-02T09:55:37Z SW Version: 07.91 Variant Version: 021 ProductProfile: RM495_0571584_07.91_021.spr Simlock: 0571584_simlock.bin SIMLOCK_DATA corrupted! yes need video SIMLOCK_DATA corrupted! |
Security Test Failed on N73... | Dirdan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 02-10-2010 10:03 |
Cant Repair Security Test Failed on N96 and 5800 | powerplay83 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 23 | 02-09-2010 17:51 |
I can't repair Security Test Failed on N96 | gsmlife | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 02-08-2010 06:44 |
my 3110c contact service security test failed.........please help me(with video File) | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-12-2009 12:22 |
To Z3X TEAM PLS Give us Server side Security to stop CTRL+C & CTRL+V | rodriges | Z3X-Team Products | 0 | 10-04-2009 00:52 |
