11-09-2012, 10:44 | #1 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1455594 Status: Offline Thanks Meter: 0 | dct4 flash loader problem SwVersion: V 5.80 14-11-08 RH-99 (c) NMP MCU file: rh99_05.800 Trying to find patch position ...OK, case id: 3 New Imei: 35854000806711 ASIC ID: 0x2292 [UPPCosto ver: 1.3] Error sending bootloader ! Boot error: AA 04 00 01 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. as u can see ive tried 3 another pc i have orange hti mx updated properly cant flash dct4 but nothing was wrong a week ago. cables are solid box is not damaged cos i can repair bb5 i saw lots of threads bout this error but no resolve why is that is mxkey team does not support dct4 or their customers. tl;dr pls help me |
11-09-2012, 10:51 | #2 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: JHELUM,PAKISTAN
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Quote:
Sometime this error occurs due to box drivers not installed or harmed by any other driver files ETC. So re-install and then check it... With me i had faced two problems like this 1st is driver problem 2nd is usb cable which connect box to PC.. Check these two options with yours... Might be it will solve WITH BEST REGARDS | |
