03-21-2012, 09:21 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | maxkey team need help n73 6120 strange prooblem SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 Imei plain: 35275701749822-0 Product code: 0529607 Battery voltage: 4664 mV, current: 266 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 352757017498220 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN i try every thing same here is rpl backup |
03-21-2012, 09:31 | #3 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 212683 Status: Offline Thanks Meter: 115 | Quote:
repaire super dongle and then write modifiy pm | |
03-21-2012, 09:35 | #4 (permalink) |
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | Phone type: RM-243 (Nokia 6120) SW version: V 06.01 02-09-08 RM-243 (c) Nokia Imei plain: 35985001435165-9 Product code: 0552780 Battery voltage: 4722 mV, current: 110 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed Failed to read SP data Failed to read SP data MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C08034DE Using device: HTI, FW ver: 00.50, SN: 0000720F Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) Phone type: RM-243 (Nokia 6120) SW version: V 06.01 02-09-08 RM-243 (c) Nokia Using cached productData. PUBLIC ID: 17B00101E1960158B2B717DCC0A1B94232040F83 PRIVATE ID: 0CC03C61C71FCA4D3109380521766E8E87F70AE1 Updating SIMLOCK ...error 0x14 Reading Simlock info ... |
03-21-2012, 10:27 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
go to tab service > imei & security > tick unlock by code > click calc nck br | |
03-21-2012, 10:29 | #7 (permalink) | |
use rev 1.5 or 1.6 and proceed with common steps in repairing security test failed if u have tried everything br | |
03-22-2012, 09:44 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. there is 1 new & simple solution, 1st update SP lock & upload pm do Super SD>Repair SD. then check the result. |
03-22-2012, 10:44 | #11 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. you done some wrong, dont do pmm auth it will not work as server offline & load pm, only repair sd & super sd auth will do the job. have a nice day. |
03-22-2012, 18:21 | #13 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | lets try again..... >do rpl backup if u have not done yet >load N73 good pm and click "erase pm" >scan the phone, repair sd or simlock (whatever error u see from logs) >write pm that u loaded(must have 1&309 field) if not solved then check bb5 certificate validation i.e. hwc,ccc.....recover them as well if needed. post results. |
03-22-2012, 18:33 | #14 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | see here, may this help u:http://forum.gsmhosting.com/vbb/f550...wered-1385480/ |
03-23-2012, 06:08 | #15 (permalink) |
Freak Poster Join Date: Aug 2009 Location: PILIPINAS'
Member: 1099075 Status: Offline Thanks Meter: 134 | ive notice that its zero bytes.. hwc -- 0 bytes ccc -- 0 bytes pls help to edit my rpl... BB5_35364101765294_BACK.rar |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
