MobiEx 3.2.1 detected virus Dear I-Mobile, I have download new version of MobiEx in support area but detected virus at Mobiex.EXE, the virus New Heur PE Virus by Eset Smart Security antivirus. Please clarify about this!!! I was disabled my antivrius n run the program but still problem with WD2 bluetooth flashing always error, please fix the problem. Thks & Regards, |
Hi, At least paste the log please, so i have better clue how to fix. BR. |
1 Attachment(s) Quote:
look br |
http://i661.photobucket.com/albums/u...e_tenso/mx.jpg |
if you not sure, send the binary/exe to your antivirus support to make sure your self. BR. |
hi, I-mobile I was fix the problem about viruses and was submit to EAV for analize, it is okay. WD2 flash Bluetooth error, logs: Nokia 3660 NHL-8 : Processing file: Nhl83050.8C1 ASIC ID: 0x1081 [UPP_WD2_v3.2,3.2E] w3_2nd.fia: [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x10D8 FlashID0: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA w3_amd.fia: [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7F10 Performing Flash Authentication ...OK UEM ID: 005F92A0:2984DA7E Programming MCU ... Nhl83050.8C1: [WD2 BT2][WD2 CBUS BT] size: 18.02 MB Area [00000000-0000FFFF] erased in 0.547 s Area [00010000-006FFFFF] erased in 58.125 s Area [02000000-023FFFFF] erased in 32.875 s Area [04000000-046CFFFF] erased in 55.484 s Flash programming ... BT MCM image (0x21): 0002DD00 Error while programming [00] at 0x00000021, Result: 0200 Flashing terminated with error(s) in 3 min 0.140 s RX Buffer: 0200000000D172 Ngage QD RH-29 : Processing file: rh2941.5c1 ASIC ID: 0x1081 [UPP_WD2_v3.2,3.2E] w3_2nd.fia: [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x10D8 FlashID0: 0001 007E [AMD 29BDS128J] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: C900 00EA 7001 00EA 7301 00EA FFFF FFFF w3_amd.fia: [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7F10 Performing Flash Authentication ...OK UEM ID: 00D15646:2984DA7E Programming MCU ... rh2941.5c1: [WD2 BT2][WD2 CBUS BT] size: 17.62 MB Area [00000000-0000FFFF] erased in 0.531 s Area [00010000-00FEFFFF] erased in 1 min 54.890 s Area [02000000-027FFFFF] erased in 1 min 1.078 s Flash programming ... BT MCM image (0x21): 0002DD94 Error while programming [00] at 0x00000021, Result: 0200 Flashing terminated with error(s) in 3 min 39.500 s RX Buffer: 0200000000F172 I flash used other tools, it is okay. Thks & regards, |
yes my nod-32 antivirus detect virus of new update |
Checking for application updates, please WAIT ... Version from app: - Executable: 3.0.0.5025 - Library: 1.0.0.4728 winsock error: No data was read because the remote system closed the connection (recv() == 0) Server temporary unavailable. |
