11-24-2009, 15:48 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Error n-gage flashing on mxkey >>>>> LOG:- Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1] SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x1058 Supported Ids: 0082 FlashID0: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: w2_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x71A8 Supported Ids: 0082 Performing Flash Authentication ...OK UEM ID: 005C12BD:2984DA7E ASIC type: 5 UEM Imei: 35152100345289 Flash Imei: 35152100345289 RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35152100345289_BACK.rpl" Processing file: nem433.0c1 as MCU [WD2 BT2,STARSHIP & BT ALGORITHM] size: 17.84 MB Supported Ids: 0082, 1081 ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1] SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x1058 Supported Ids: 0082 FlashID0: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: s2_amd_b.fia [STARSHIP & BT ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7B78 Supported Ids: 0082 Performing Flash Authentication ...OK UEM ID: 005C12BD:2984DA7E Area [00000000-0000FFFF] erased in 0.687 s Area [00010000-006FFFFF] erased in 1 min 13.140 s Area [02000000-023FFFFF] erased in 45.125 s Area [04000000-046A3FFF] erased in 1 min 13.672 s Flash programming ... BT MCM SwID: 22 ,Error while programming [25] at 0x00000000, Result: 00B3 Flashing terminated with error(s) in 4 min 52.547 s RX Buffer: 00B372 |
11-24-2009, 19:03 | #4 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | THANKS ALL FOR SHARE KNOLAGE, SET FLASH OK HEARE IS BUS CHEK LOG:- Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11443, Date: 23-11-2009 ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1] SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x1058 Supported Ids: 0082 FlashID0: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 257E [AMD Am29N643G,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Algorithm: w2_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x71A8 Supported Ids: 0082 Performing Flash Authentication ...OK UEM ID: 005C12BD:2984DA7E ASIC type: 5 UEM Imei: 35152100xxxxxxx Flash Imei: 351521xxxxxxxx MasterCode: 2511563267 RPL saved to "C:\mobileEx\3.3\data\backup\35152100345289_BACK.rpl" Phone Type: NEM-4 (Nokia N-Gage) SW Version: V 3.30 28-08-03 NEM-4 (c) NMP. Imei plain: 3515210xxxxxxx-3 Cellular System: GSM ASIC ID: 0x0082, type: 5 Language Pack: - not available. Imei net: 351521003xxxxx Version: SIMLOCKLIB VERSION 2.26 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000005 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
"e-72"-dead after flashing on mxkey? (ANSWERED) | jasimbinrashid | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 04-04-2011 04:27 |
how to unlock "htc g-1 anroide?on mxkey? | rashidbinu | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 1 | 03-29-2010 16:08 |
6600i Slide error flashing on Mxkey | yobb | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 12-16-2009 15:19 |
Flashing error on mxkey to 3.2 rev 5.6 | archi3 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 11-07-2009 22:00 |
5200 Flashing Error on mxkey need help | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 06-02-2009 03:51 |
