05-19-2010, 15:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: NIGERIA
Member: 676315 Status: Offline Thanks Meter: 120 | Mx key team or member what is this? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1720010636366B56478684461F0B6ADA62BE887D ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 635D34C3C5F94991906E11ED6990BF705B4DB951 Original Imei: 35552301103290 Original Product code: 0544345 Bluetooth ID: 001B3365B2CE Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35552301103290-3 Product Code: 0544345 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355523011032903 Version: SIMLOCK SERVER VERSION 63 SIMLOCK SERVER VERSION 63Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF AND WHEN I DO PMM AUTH IT'S WORK FINE WITHOUT A SINGLE ERROR Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.190.2.152 SUPERDONGLE authorized ! BUT WHEN I TRIED IT WITH NOKIA 3110C SHOWING SECURITY TEST FAILED SUPER AUTH AND PMM AUTH FAILED FOR 5 TIMES AND HERE IS THE PHONE LOG Phone Type: RM-237 (Nokia 3110c 6r Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35602903093604-0 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356029030936040 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF AND THIS WHAT IT'S SHOW EVERYTIME I DO THE SUPER AUTH AND PMM AUTH WITH PHONE WITH SECURITY TEST FAILED FOR TH PAST 12 DAYS AND HERE IS THE LOG Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[2C800103D61A8B560972ADAAF3BB4805E0C30510] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request CAN MX KEY TEAM OR MEMBER EXPLAIN TO ME WHAT THIS IS, AND WHY THEY ARE HAPPENING. |
The Following 2 Users Say Thank You to wisdom001 For This Useful Post: |
05-19-2010, 15:40 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | firewall problem uninstall mxkey and install it again |
The Following User Says Thank You to rakesh15 For This Useful Post: |
05-19-2010, 17:58 | #6 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: IRAN
Member: 1196610 Status: Offline Thanks Meter: 34 | Quote:
05-19-2010, 19:04 | #10 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | tyr this backup rpl rest npc go to pm click erase pm writ rpl then click recover cert simlock> click splock info then tick make simlock rpl then click update simlock repair sd go to pm >tick load rfbb from server then click SUPER SD AUTH and writ pm fullfactory&format |
05-20-2010, 06:28 | #12 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 812422 Status: Offline Thanks Meter: 18 | Quote:
RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 172000115F297D56D0BCD047F27152142A83B028 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Begin Certificate Request ... [InternalErrorFault] CERT [0572571] data not found in database (case id=0xCE02) | |
05-20-2010, 06:32 | #13 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 469011 Status: Offline Thanks Meter: 33 | try this is 100% solution this is tested by me riper sd after load this modified pm 3110 Full Modified PM.rar click sd autho write pm your pro solv 100% |
05-20-2010, 07:27 | #14 (permalink) |
Member: 676315 Status: Offline Thanks Meter: 120 | tried many times but no luck, but the funny thing about it is that repair sd and simlock repair for bb5 phones is working and rpl repair and simlock repair for dct4 is working but sd auth and pmm for phones showing security test failed is not working at all. if you guy think i am lying let someone that has error when doing sd auth and pmm should try it with working phone and you will see that it's will authorise, why all this. here is the rpl that you request for RapidShare: 1-CLICK Web hosting - Easy Filehosting |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
