05-28-2011, 18:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: United State
Member: 229658 Status: Offline Thanks Meter: 60 | N900 maltunction "All telephony functions, including emergency calls, are disabled due to a communication error. To recover, you might have to reboot the device" HERE IS THE FILE I DOWNLOADED AFTER EXTRACTING. RX51_0574386_20.2010.36.2_001.dcp RX51_0574386_20.2010.36.2_001.vpl RX51_0574386_20.2010.36.2_001_signature RX-51_2009SE_20.2010.36-2_PR_COMBINED_MR0_ARM I SELECTED "RX-51_2009SE_20.2010.36-2_PR_COMBINED_MR0_ARM" AS THE MCU. Here is the log: Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Remove USB cable from device. Turn off the phone Press and hold down key 'u' Connect USB cable between the phone and host PC while still holding down key 'u' When USB cable gets connected it powers the phone and set's it to flashing mode SW version in image: RX-51_2009SE_20.2010.36-2_PR_MR0 Image 'kernel', size 1705 kB Version 2.6.28-20103103+0m5 Image 'rootfs', size 185728 kB Version RX-51_2009SE_20.2010.36-2_PR_MR0 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.9+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.9+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.9+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.9+0m5 USB device found at bus-0, device address \\.\libusb0-0001--0x0421-0x0105. Found device RX-51, hardware revision 2101 NOLO version 1.4.14 Version of 'sw-release': RX-51_2009SE_20.2010.36-2_PR_MR0 Sending xloader image (14 kB)... Sending secondary image (106 kB)... Flashing bootloader... done. Sending cmt-2nd image (79 kB)... Sending cmt-algo image (507 kB)... Sending cmt-mcusw image (5826 kB)... Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... Flashing kernel... done. Sending and flashing rootfs image (185728 kB)... Finishing flashing... done Erasing CMT ... Waiting for phones to boot up ... Sleeping for 15 seconds while device boot up ... |
6230i CAMERA NOT WORKING - N900, N901 AND C907 MISSING | fusion007 | Nokia Hardware & Hardware Repair | 5 | 02-15-2008 15:01 |
N900 | akcel | Chinese Cocktail | 9 | 01-05-2008 09:14 |
nec n900 wanted | mikezito | Wanted Products | 1 | 05-02-2006 22:45 |
1 x brand new N900 for sale | stanic | Sell ur Old and Used Stuff | 1 | 11-23-2005 20:20 |
Nec N900 Phone | ali42 | NEC | 1 | 08-29-2005 12:30 |
