09-20-2010, 14:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: india
Member: 1158702 Status: Offline Sonork: http://www.zentex.in/ Thanks Meter: 79 | N 72 Dead After Flash(ANSWERED) Version from phone: 05wk07v48.2 Version from file: 50819401.C0 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35696601328342_BA CK.rpl). Processing file: RM180_50819401.C0 as MCU [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 28.69 MB Supported RAP Ids: 0003192101012200, 000C192101012200 Supported APE Ids: 17100701, 17100702 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 14E0000DBE7E5D51BE0398AFF0CDD76529449A7A ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0033 - 0000 0121 [AMD S29NS064N,64 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 Partitioning ...OK Erase size: 68.92 MB CMT NOR area [00000000-0052B6C1] erased in 27.281 s CMT NOR area [006A0000-006BFFFF] erased in 0.172 s CMT NOR area [006DF000-006EFFFF] erased in 0.860 s CMT NOR area [00700000-007EFFFF] erased in 6.203 s APE NAND area [00000000-0000FFFF] erased in 0.172 s warning : erase sector address out of chip bound. APE NAND area [00010000-0001FFFF] erased in 0.156 s warning : erase sector address out of chip bound. APE NAND area [00020000-000203FF] erased in 0.156 s warning : erase sector address out of chip bound. APE NAND area [00050000-03ECFFFF] erased in 0.265 s warning : erase sector address out of chip bound. Flash programming ... CMT PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (Rap certificate3) written. Error chk C7012D0100D0000010000000F1 Error while programming [01] at 0x00000000, Result: 0010 Flashing terminated with error(s) in 1 min 18.500 s RX Buffer: C7012D0100D0000010000000F172 Please Give Me Solution Thanks In Advance. |
The Following User Says Thank You to er.shivam For This Useful Post: |
09-21-2010, 07:14 | #5 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | Quote:
06-30-2011, 14:13 | #7 (permalink) |
Junior Member Join Date: Jan 2007
Member: 441748 Status: Offline Thanks Meter: 0 | thr same problemwhile n73 flashing - MXKEY Serial: [FT SCR2000 0] - C0809D4F Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2800020560EF0154E7325FF04797834C804DF07C ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 Processing MCU file: N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 46.93 MB Supported Ids: 0103192101003000, 010C192101003000 Supported Ids: 17100708 Partitioning ...OK Erase size: 91.38 MB CMT NOR area [00080000-0073194D] erased in 42.811 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 5E8D0D504A0902E261268C14FCD8A2C9093523BC (Rap Certificate 26 v1) sent CMT UPDAPP block sent CMT ADL block sent CMT DSP0 block sent CMT MCUSW block sent Error chk C7012D0100D0000010000000F1 Error while programming [01] at 0x00000000, Result: 0010 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 00 D0 00 00 10 00 00 00 F1 72 the phone problem before waswhite screan and no starting... now i can read info, but can't reflash it. still white screan and does not start info log: Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61 09-07-08 RM-133 (c) Nokia. Imei plain: 35956901030785-9 Product Code: 0539284 Battery voltage: 4693 mV, current: 67 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359569010307859 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN try to use ufs & phoenix but they olso can't reflash it... can anyone help me? thx |
5110 v 6.0 after unlocking problem with net | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 16:11 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
