06-24-2009, 12:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | nokia 1200 dead problem in new update flashing ok but not power on set is dead ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016E547A3BDA66 ASIC type: 11 UEM Imei: 35293202485724 Processing file: rh99_05.800 ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016E547:2984DA60 Programming MCU ... rh99_05.800: [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Area [01000000-0100FFFF] erased in 1.078 s Area [01010000-013AFFFF] erased in 1 min 4.343 s Area [013B0000-013EFFFF] erased in 4.359 s Area [017C0000-017EFFFF] erased in 0.032 s Area [01FC0000-01FEFFFF] erased in 0.031 s Flash programming ... Programming completed in 13.391 s File Processed in 1 min 42.750 s Processing file: rh990_nai5.80mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016E547:2984DA60 Programming Content Pack ... rh990_nai5.80mg: [DCT4,DCT4 ALGORITHM] size: 151.96 KB Supported Ids: 2292 Area [01380000-013AFFFF] erased in 3.297 s Flash programming ... Programming completed in 0.907 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.078 s File Processed in 15.156 s Processing file: rh99_05.06mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016E547:2984DA60 Programming PPM ... rh99_05.06mg: [DCT4,DCT4 ALGORITHM] size: 994.82 KB Supported Ids: 2292 Area [01240000-0124FFFF] erased in 1.140 s Area [01250000-0137FFFF] erased in 21.094 s Flash programming ... Programming completed in 5.890 s File Processed in 46.609 s Flashing completed in 3 min 6.422 s Phone not responding ! Total time to process is 3 min 32.125 s plz help mx-key how to solv this problem |
06-24-2009, 16:44 | #2 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Quote:
Are you sure the phone is DEAD AFTER flashing? CNT extract completed, means it not DEAD. Phone not responding message is because phone not entered to LOCAL MODE correctly, please just switch the phone manually and re-scan. BR. | |
06-24-2009, 18:04 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | mean is Code: Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.078 s and you put wrong package mcu = rh99_05.800 cnt = rh990_nai5.80mg ppm = rh99_05.06mg br, |
The Following User Says Thank You to Andra For This Useful Post: |
Problem in new UPDATE... Please HELP!! [ Solved ] | parengBok | Cyclonebox | 8 | 01-25-2010 05:59 |
i face this problem in new update | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 11-25-2009 18:01 |
Hello z3x team problem in new update | rajen212 | Z3X-Team Products | 2 | 11-13-2009 16:27 |
*-*i have problem in new update USTPro V525_R2*-* | mr.6630 | UST Pro II | 12 | 09-01-2007 18:00 |
