06-21-2009, 10:26 | #1 (permalink) |
Banned Join Date: Feb 2007
Member: 445578 Status: Offline Thanks Meter: 440 | Mx key bug, flashing problem weak flashing u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00441602:2984DA60 ASIC type: 2 UEM Imei: 35367001127704 Flash Imei: 35367001127704 RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35367001127704_ba ck.rpl" Processing file: rh93_07.020 ASIC ID: 0x2201 [UPP_v2.2x] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00441602:2984DA60 Programming MCU ... rh93_07.020: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 1.89 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Area [01000000-0100FFFF] erased in 0.484 s Area [01010000-013BFFFF] erased in 27.578 s Area [013C0000-013EFFFF] erased in 1.469 s Area [017C0000-017EFFFF] erased in 0.047 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Error finalization ! Programming completed in 1 min 26.156 s File Processed in 2 min 12.610 s Processing file: rh930_nai7.02ic ASIC ID: 0x2201 [UPP_v2.2x] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00441602:2984DA60 Programming Content Pack ... rh930_nai7.02ic: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 155.16 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Area [01380000-013BFFFF] erased in 1.906 s Flash programming ... Error finalization ! Programming completed in 1 min 2.266 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.078 s File Processed in 2 min 35.296 s Processing file: rh93_07.02ic ASIC ID: 0x2201 [UPP_v2.2x] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00441602:2984DA60 Programming PPM ... rh93_07.02ic: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 1.36 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Area [011E0000-011EFFFF] erased in 0.468 s Area [011F0000-0137FFFF] erased in 11.781 s Flash programming ... Error finalization ! Programming completed in 1 min 19.125 s File Processed in 1 min 47.953 s Flashing completed in 8 min 28.985 s Phone Type: RH-93 SW Version: V 7.02 10-12-07 RH-93 (c) NMP Imei plain: 35367001127704-6 Product Code: 0537104 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Total time to process is 8 min 44.344 s |
06-21-2009, 10:43 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: LOVE A L L AH LOVE ALQURAN
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | please try lower version 6.0 some time uper version not support r try selcet full erase keep in mind may be u need a pm if signal not come |
06-21-2009, 11:03 | #4 (permalink) |
Member: 445578 Status: Offline Thanks Meter: 440 | mx key flash process is so slow. and when finishing MCU flash then show Error finalization ! after that, PPM Flash also show that and take long time(at that time can be flash 2 mibile by jaf or ufs) and also take long time for unlocking............... please MX-KEY team fixed this problem for your's product! |
06-21-2009, 11:05 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | yup, I am facing same problem with mx-key last version, bug in flash dct4 phones.. MobileEX Team will check & solve this problem soon. |
06-21-2009, 12:15 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
everyone can see ??? yep we know that. if u use JAF interface have that problem. why u not try in UFS interface ? lets try bro.. br, | |
The Following 2 Users Say Thank You to Andra For This Useful Post: |
06-21-2009, 16:27 | #8 (permalink) |
Freak Poster Join Date: Nov 2008 Location: WEST JAVA
Member: 898057 Status: Offline Sonork: unvailable Thanks Meter: 85 | yes i,m ever same trouble like this,,, and i tryng with box ufs,, flashing result so good, mxkey-team why u dont have owner box interface, we all waiting for that. for me,, u,r already great software but the interface u dont have. if u have good interface owner.mxkey will the best |
06-21-2009, 17:16 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Yes i m agree about this this is very slow working and flashing i post maney time that this is very slow but no response i kindly reqwest tou mx-team plz do fast flashing 1200 1208 totly flashing time expen 15 minuts so very slow |
06-24-2009, 17:41 | #12 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Quote:
bug fixed, check new release (rev 2.2) BR. | |
06-24-2009, 17:47 | #13 (permalink) | |
check this link: http://forum.gsmhosting.com/vbb/show...42&postcount=4 BR. | |
The Following User Says Thank You to Alim Hape For This Useful Post: |
REPORT MX-Key bugs and problems here... | Burnt Cobba | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-10-2010 09:07 |
2310 flashing with mx-key what's the problem | mamoorabi | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-03-2010 14:32 |
can mx key sove the problem | seeta | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 01-20-2010 08:26 |
mx-key new update problem | gsmshapon | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-19-2010 09:37 |
mx key server access problem | chandan_123 | Various CDMA/TDMA Cell Phones | 1 | 11-08-2009 05:58 |
