07-29-2010, 08:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Age: 37
Member: 1149013 Status: Offline Thanks Meter: 247 | mx key can not wrire imei ?????? repire MCU SW version: V 03.10 21-01-09 RH-112 (c) NMP HW version: 2001 UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_08w31_UPP LCD version: WIN:SERI:8a NT7542 PPM version: V 03.10 21-01-09 RH-112 (c) NMP IC ADSP SW version: p V 03.10\n21-01-09\nRH-112\n(c) NMP\nic Product Info: Production serial number: IMO223013 Product code: 0569745 Module code: 0204036 Basic production code: 0574232 Serial Numbers: IMEI plain: ??????????????? IMEI spare to net: FA FF FF FF FF FF FF 0F IMEI SV to net: F3 FF FF FF FF FF FF 1F F5 Other Info: CS type : GSM/DCS1800 BSI: 4.5 KOhm Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA every person when tell me.this method Hope this helps you, 1. Check Bus 2. Select service and click on imei & security 3. Select online logger and login 4. After login select DCT4PLUS IMEI and click Do Selected Job when i used this method......not solved my prob... error showing this msg... ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 002D765EA3BDA66 ASIC type: 11 UEM Imei: 35523C03499668 Invalid uem checksum, UEM might be damaged ! [InternalErrorFault] IMEI/ESN (35523C03499668) contains non digit char, probably UEM damaged ! (case id=0xCB01) |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
