MX KEY CANT DETECT MY UFS AND JAF help is there any procedure out there? , i've tried uninstalling the ufs usb driver and install the driver from mobilex folder, still mx key cant detect my ufs and jaf, tried using the FTCLEAN from mobilex problem remains, even tried changing my ufs serial no. and updating the firmware .... tried using 3 different ufs box again nothing happens..... ive down loaded the latest updates of mxkey still the problem is the same....... mx key team help ........... |
Might be the problem of Hardware MX Key has two things. 1) Smart Card 2) P-key It might be the problem of P-key. Please try to install in another computer. Still, there is problem, then, plug out the "Smart Card" and put it to another "P-Key" or Box that you have. Download the GIF file and watch out:-- ============================ http://www.MegaShare.com/1649574 Password:- sairam |
smart card and reader is working fine because i have succesfully registerd my mx key and updated it also.. my problem is mx key cant detect any of my ufs and jaf box's... i even tried using it in another computer still the same......now i cant sign my mxkey application because i've use up all my 5 attempts :mad: |
------------------------- new with mobileEx? try re-scan or click on "NO CONNECTiON". Are you sure has been installed driver correctly. Look at device manager, and attach infos here. Make sure USB A-B cable is, ok. do not plug a lot of devices to your computer usb. |
gggggggggggggggggggrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!! !!!!!!!!!!!!!!!!!!!!!! |
@ marvin03 what are you trying to tell us? :D |
usb cable is fine, i even tried using a brand new usb cable:mad:...... im sot sure about the driver though??????? tried un installing ufs usb driver ang install the one that is inside the mobilex folder C:\mobileEx\3.3\data\drivers\ufs\2.4.16.0 still it shows not connected........ |
what u wana say explain plz :D |
the file is mobileEx.xml. you can use it anywhere else, no need to sign via server again. a question, what other tool (ftdi based) installed, beside mxkey? br |
well then, can jaf use ufs on that computer? br |
yes its all working........ but whenever i start mobilex it ask for a driver... i choose the driver from C:\mobileEx\3.3\data\drivers\ufs\2.4.16.0 and overwrite the previous driver, but still it cant detect my ufs or jaf...... am i using the write driver? thnx |
i mean right not "write" driver:D |
You can report any info after doing these; 1. After you open mobileEx, copy your "Loaded drivers" log here. 2. print into docs/make screenshot of device manager and attach here. 3. Uninstall all driver from uninstaller program. Make sure that you unplug all ftdi/card from computer. 4. Restart and manual delete driver from system if any. 5. Now install one-by-one, firstly ufs driver and then mxkey. Maybe your driver ver ; 3.1.05.0, sorry if i'm wrong... :D Newer driver ver; 3.4.16.0 |
did you mean 2.4.16.0 and not 3.4.16.0?........ Quote:
CAN you upload your driver here thnx |
