Old 08-06-2012, 05:02   #1 (permalink)
amit_gsm's Avatar
Member: 665514
Sonork: 100.1618806
Thanks Meter: 325
Red face Mx-key Driver Not Found Need Help
My Mx-key Driver Not Found
But Mx-Box Is Ok
Need help
The Following User Says Thank You to amit_gsm For This Useful Post:
Old 08-06-2012, 05:07   #2 (permalink)
Member: 862260
Sonork: 100.1612919
Thanks Meter: 156
uninstall and reinstall and tic smart card driver in reinstalling
Old 08-06-2012, 07:04   #3 (permalink)
amit_gsm's Avatar
Member: 665514
Sonork: 100.1618806
Thanks Meter: 325
Hti box is ok
But My Mx-key dongle is not Ok
No Driver Found
Need Help
Old 08-06-2012, 08:36   #4 (permalink)
..:: SONY ::..'s Avatar
Member: 1528548
Sonork: 100.1613286(Offline)
Thanks Meter: 2,243
Follow this link
http://forum.gsmhosting.com/vbb/f550...ivers-1454408/
Old 08-06-2012, 10:45   #5 (permalink)
amit_gsm's Avatar
Member: 665514
Sonork: 100.1618806
Thanks Meter: 325
Talking My Problem Solved
My Problem Solved
Used This Link GO
I Flashed C2-03
MXKEY [FT SCR2000 0], SN: C0842478
Using device: USB ROM
Connection status: OHCI:HUB::USB 1.10 (Full-speed)
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3327FA29
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35973604673946
IMEI_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35973604673946_ back.RPL"
Processing file: rm702__07.57.mcusw
Downloading item CODE:rm702__07.57.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.375 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.703 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 36.797 s
Checksum verified (0xCE42)
Processing file: rm702__07.57.ppm_mh1
Downloading item CUSTackage_mh1.ppm_ebl_psi.fls, num block: 1, size: 4.86 MB
Erasing area 0x41DC0000-0x4229B14A ...OK
Programming completed in 6.813 s
Checksum verified (0xDA8F)
Processing file: rm702__07.57.image_mh1_059P4Z9
Downloading item CUSTackage_mh1_059P4Z9.image.fls, num block: 1, size: 13.88 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 19.125 s
Checksum verified (0xCAD3)
Total time for flashing process(boot+erase+write) was 7 min 41.125 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: BA76FF6
Verifying communication to device OK.
Phone type: RM-702 (C2-03)
SW version: V 07.57 22-06-12 RM-702 (c) Nokia
Imei plain: 35973604673946-8
Product code: 059D463
Language Pack:
- not available.
Imei net: 35973604673946
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Thanks My Friend's
Old 08-06-2012, 11:21   #6 (permalink)
Member: 1528548
Thanks Meter: 2,243
Problem Solve Thread Closed
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.33926 seconds with 10 queries
